Thread: Denon avr 2805 vs HK avr 430 |
Gianluca Tarei Unregistered guest |
| Posted on Tuesday, January 18, 2005 - 02:23 pm: |
hi all, I need an advice. I'm just upgrading my ht system and i can't decide between the two amps in the subject. I will use it for music and movies 50%/50% with jbl northridge e100 as main speakers and jbl e20 / e25 as surround speakers. I'd really appreciate your opinions. Thank you! |
Bronze Member Username: Dloweman
Post Number: 52 Registered: Nov-04
| Posted on Tuesday, January 18, 2005 - 02:28 pm: |
As the jbl's are on the revealing side, matching them with the HK would probably be your best bet, but listen to them with both and see which you prefer. |
| Posted on Wednesday, January 19, 2005 - 08:53 am: |
Thanks. Probably I won't listen to denon with jbl ( I can't find anyone who has both), but if the other combination sounds good, it will be mine! |
