Thread: Fuse on Marantz Model 2 |
Big Luni Unregistered guest |
| Posted on Monday, January 17, 2005 - 01:42 pm: |
I have two Marantz Model 2 Amps hooked up to a Fairchild 245 Preamp. Recently, the main fuse on one of the Model 2's blew for no apparent reason. Needless to say, changing the fuse didn't help. It will blow after the amp has been warming up for about 30 seconds. Anyone know the most common causes for this? |
J. Vigne Unregistered guest |
| Posted on Tuesday, January 18, 2005 - 08:32 am: |
Probably power supply problems, likely a bias resistor or a capacitor; could be both, one taking out the other. How long have you had these units and when was the last time you had them in for service or maintenance?
New member Username: Big_luni
Hartford,
CT
Post Number: 2 Registered: Jan-05
| Posted on Tuesday, January 18, 2005 - 09:52 am: |
It's been a while. I guess I'm gonna have to bite the bullet & find someone to look at them. I was just hoping for an easy answer! |
