Home > Message Board > Home Audio > Subwoofers > Archive through March 05, 2005 > What Jl Audio amp configuration could...
Author Thread: What Jl Audio amp configuration could I use for 2 12" W3v2's
Username: Surfer6099
FL
I have money that I have saved and I dont know what to do audio system wise. I was looking at the 12" w3v2's but they are 300w RMS and I dont know what Jl Audio amp i would run on them. I was thinking that a 500/1 would be good for each or a 1000/1 but thats expensive and I think that would be pushing to hard. What JL amp do you think I should use and what other Jl Audio subs and equipment do you recommend.
Username: Agazdecki
The 500/1 is the perfect amount for those subs. I have 2 10" running off one 500/1. If you were to run a 1000/1 they would blow in a week. 250rms each is enough to make these subs pound so hard youll head will hurt.
Home > Message Board > Home Audio > Subwoofers > Archive through March 05, 2005 > What Jl Audio amp configuration could... [ « Previous ] [ Next » ]
