Home > Message Board > Home Audio > Amps > Archive through March 20, 2005 > Help Denon AVR-3805 & DVD-2900 SACD I...
Author Thread: Help Denon AVR-3805 & DVD-2900 SACD Interface
Username: Rocky
I recently purchased a Denon AVR-3805 amp and a Denon DVD-2900 player. Can anyone tell me how to interface the two devices so that I can play SACDs? The 3805 has Denon Link, but unfortunately the 2900 does not. Obviously I don't understand the manuals.
Rocky
Username: Rocky
The following is provided as amplification to my problem of interfacing a Denon AVR-3805 amp with a DVD-2900. The six audio output jacks on the rear of the DVD-2900 are obvious. My problem is that I do not see where they should be plugged into the rear of the AVR-3805.
Rocky
Username: Natish
India
Your Denon 3805 have an multi-channel input.From ur DVD 5.1 analog out just connect respective outs 2 the 3805 multi-ch in's.In ur player u have 2 change the setting for analog out from 2ch to 5.1ch.
Best of luck
Username: Usa2k4
Post Number: 80
Yes, as said, in order to play multichannel SACD's or DVD-A's you'll need to connect the 5.1 output on the player to the 5.1 input on the receiver. You'll need to run speaker setup on the player because direct 5.1 input mode would bypass the bass management on the receiver.
Home > Message Board > Home Audio > Amps > Archive through March 20, 2005 > Help Denon AVR-3805 & DVD-2900 SACD I... [ « Previous ] [ Next » ]
