Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through February 13, 2004 > Is that Kenwood AV Receiver KRF-V5070...
Author Thread: Is that Kenwood AV Receiver KRF-V5070D-S is a good receiver ?
Username: Alexandermow
This is it spec..
DTS 5.1 ch, Dolby Digital 5.1 ch, Dolby Pro Logic II 5.1 ch decoding
3 Active EQ mode
5 DSP listening modes
Digital AM/FM tuner: 40 presets
Remote control unit (with the capability of controlling Kenwood DVD Players)
2003 new generation stylish flat board design & easy unit operation
Surround power output: 100W x 5 (FTC, 8 ohms, 0.7% THD)
Terminals
3 digital inputs (1 optical, 2 coaxial)
6 audio inputs (including Phono MM and 6 ch input)
2 Audio outputs
3 visual inputs
2 visual outputs
Subwoofer Pre out
6 ch input for DVD Audio reproduction
Amplifier features
24-bit Cystal DSP
24 bit resolution D/A, A/D converters
96kHz/24 bit audio reproduction capability
Midnight mode (Dynamic compression system in Dolby Digital mode)
Independent speaker level control adjustment
2 AC outlets
Loudness control
Bass boost
Full Auto Digital Analogue Input Selector
Set up memory for each channel/Input sensitivity control
(Input level adjust by 3 steps)
Digital REC mode: Auto/Manual
Display dimmer function
Dimensions and weight
W: 440mm x H: 143mm x D: 303mm
9.3kg
Please give some opinion about this receiver.
Username: Project6
Post Number: 240
that is a very nice receiver without the heat problems of the newer krf-6070
cheers
Username: Project6
Post Number: 241
oops, make that 7060D
Sarandon
i had the kenwood vr-6050 and i did not like the sound of the receiver, although i should have gotten the vr-6070!! but anyway kenwood makes a good receiver for the money, but their are some better choices out there. plus i can already tell you that you will not like the 3 Active EQ mode and the 3 Speaker EQ mode. they make the sound so dull. But you will like the Circle Surround II modes it has, to me i like it better than DPL II!
oh and the 5 DSP listening modes suck a$$ bigtime!!! i know there are 5% of people including me that uses the DSP modes that a receiver offers. If you like DSP modes then i would recommend yamaha for dsp. since the invented them back in 1986.
Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through February 13, 2004 > Is that Kenwood AV Receiver KRF-V5070... [ « Previous ] [ Next » ]
