Thread: Wanted: Harman Kardon AVR-430 Service manual |
Bronze Member Username: Dary
São Paulo
Brazil
Post Number: 33 Registered: Apr-04
| Posted on Tuesday, January 11, 2005 - 02:05 pm: |
Thanks in advance for any suggestions to where I can get the AVR-430 service manual!!! Needed to solve setup memory failure. Already tried Harman and local representative. Thanks again for any help. |
Silver Member Username: Kano
Post Number: 250 Registered: Oct-04
| Posted on Tuesday, January 11, 2005 - 03:31 pm: |
http://manuals.harman.com/HK/Owner%27s%20Manual/AVR%20430%20OM%20FINAL%20(REV%201-5-04).pdf
São Paulo
Brazil
Post Number: 34 Registered: Apr-04
| Posted on Tuesday, January 11, 2005 - 07:10 pm: |
Kano, Thanks, but this the owner's manual. I need the SERVICE manual. Or at least some directions to where is located the setup memory power circuit. HK support says that a special capacitor needs replacement. Regards. |
Bronze Member Username: Afrogt
Post Number: 21 Registered: Dec-03
| Posted on Wednesday, January 12, 2005 - 01:56 am: |
The 430 can't be 2 years old. It should still be under warranty. Why not just send it in for repair? |
São Paulo
Brazil
Post Number: 35 Registered: Apr-04
| Posted on Wednesday, January 12, 2005 - 05:40 am: |
Hi Greg, The unit has been bought in Brazil, where we get only 6 months warranty. Also, there is no local service center. I could send it to America but shipping costs and customs papers could exceed unit value. Thanks anyway |
São Paulo
Brazil
Post Number: 37 Registered: Apr-04
| Posted on Thursday, January 13, 2005 - 06:35 pm: |
Any ideas?? The e-mail of a service center may help! Please... |
dkendall Unregistered guest |
| Posted on Friday, January 14, 2005 - 08:29 am: |
http://manuals.harman.com/HK/Service%20Manual/AVR430-630%20sm.pdf That was the first hit on google for 'AVR430 Service Manual'. I assume you didn't try very hard to find it. ;)
São Paulo
Brazil
Post Number: 38 Registered: Apr-04
| Posted on Friday, January 14, 2005 - 01:24 pm: |
dkendall, Thanks a lot!!! You wouldn´t believe how many times I tried this search on Google! I even tried to modify the URL to the user manual, assuming service manuals URL could be the way you found out... but didn´t have your luck. Regards. |
