Home > Message Board > Home Audio > Receivers > Archive through January 19, 2005 > New to the board please help me with...
Author Thread: New to the board please help me with this problem
Username: Hrtbeat2
Riverview, Fl
Usa
I bought a new Onkyo 702 it's 7.1 channels 100watts and so on. I also have a samsaung HD DVD player with Infinity TS450 speakers with a seperate Infinity center. I'm running DVI from the DVD player to the TV which is a 42' HDTV and a fiberopti cable to the back of my receiver. All else is component monster cables. The problem I'm having is when I'm playing a movie or at the setup area I get popping noises coming form the speakers? I've called onkyo and they said I'm the first to call with that problem. I went back to Circuitcity and had them hook up my unit and it did the same thing and theirs did to?? So I noticed that when running just Red/yell/white it doesn't do it?? I have all speakers set to small, great connections with 18 gauge wires)THX) and gold tips. So I don't know what to do?
J. Vigne
Suggest to Onkyo you be the first to get your receiver fixed for that problem. If they don't like your suggestion, you could make it a demand.
Home > Message Board > Home Audio > Receivers > Archive through January 19, 2005 > New to the board please help me with... [ « Previous ] [ Next » ]
