Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through February 13, 2004 > Which one would you buy if you will ...
Author Thread: Which one would you buy if you will have the money?
Username: Rmihai
Sony - STRDE985
Pioneer - VSXD912
Kenwood - VR7070
Yamaha - RX596
Panasonic - SAXR10
Yamaha - HTR5660
Denon - AVR1603
Onkyo - TXSR501
Onkyo - TXSR600
Panasonic - SAXR45
Panasonic - SAHE200
JVC - RXDV5SL
Sony - STRDE995
Username: Gdawg
Post Number: 67
Micheal,
It really depends on the speakers you plan on buying, or what you have already. What speakers do you own?
It Also heavily depends on personal preferences, for some, Kenwoods THX or user interface might be important, for others Pioneers MCACC is more important. With that long of a list, you have to really go and try each out for yourself. Each has its ups and downs, what you have to find out is what you need and dont.
The sound however, is the byfar MOST important thing. All receivers are fairly user freindly, and sound should be first. If you have a pair of speakers already, see if you can find a local dealer and bring your speakers in. This is the best way to find the best receiver, but start first by "trying out" each receiver and seeing which apeals most.
G.DawG
Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through February 13, 2004 > Which one would you buy if you will ... [ « Previous ] [ Next » ]
