Thread: Loose Headshell |
New member Username: Rossco
Post Number: 1 Registered: Jan-05
| Posted on Wednesday, January 05, 2005 - 12:19 pm: |
Hopefully someone on here can verify this for me. Firstly, i'm a newbie to turntables, so please dont laugh if i'm stating the obvious!! I have just bought a Pro-ject Debut 2 turntable and the headshell is quite loose, should it be?? I have noticed if I swivel it around there is a small hole that looks like a screw may fit in it, but one wasn't supplied?? Any help with this would be greatly appriciated! Thanks.. Ross M |
J. Vigne Unregistered guest |
| Posted on Wednesday, January 05, 2005 - 01:45 pm: |
Call the dealer who sold you the table.
New member Username: Voiceprint1
Post Number: 1 Registered: Mar-05
| Posted on Tuesday, March 22, 2005 - 03:25 pm: |
buy a blank headshell from guitar center, it will contain a fresh set of mounting screws, use these to mount your headshell onto the tonearm. you need two screws to properly align the cartridge, which is also your next step. all project tables are of a very high quality. |
