Home > Message Board > Home Audio > Preamps > Archive through November 28, 2005 > Recommendations on PRE-AMP ?
Author Thread: Recommendations on PRE-AMP ?
Username: Stifa
Post Number: 20
I have Arcam Alpha 9p Power Amp, and I need a pre-amp with two sets of outputs for bi-amping in future.
Please recommend models you have experienced that could go well with Arcam.
thanks
Username: Frank_abela
Berkshire
UK
Post Number: 335
Marko,
There are loads to choose from. If you wanted to biamp immediately, you could buy an Arcam A90 and biamp with the P9 which would be a good partnering. Arcam also make the FMJ C30 preamp which is excellent.
The Cyrus Pre-X has three preouts so you could triamp with that model. It's a cooler presentation which is probably a good thing since the Arcams, particularly the older models, are quite warm.
That's just a couple in a long list that could be worth your while looking at.
Regards,
Frank.
Username: Jinamann
When I try to run cassette tape to my philips stand alone CD burner I get a very low signal, Not enuff to move the meter on the burner!
When I use a turn table I have no problem.
I run the gear into a 10 band EQ & even with that I can't boost the tape singnall enuff to burn a disc! My guess is I need to run some kinda amp between the tape & CD burner.
Any ideas on what I need.
Jinamann
Home > Message Board > Home Audio > Preamps > Archive through November 28, 2005 > Recommendations on PRE-AMP ? [ « Previous ] [ Next » ]
