Thread: Speakers for Mirage Omnisats |
Unregistered guest |
| Posted on Friday, February 06, 2004 - 03:25 pm: |
Hi.. I've decided to go with the Mirage Omnisat speaker set up. Probably with a Hsu subwoofer. It's in a basement (in Michigan) with 8 foot acoustic tile ceiling. The room is about 25 x 35 overall. I'll 'divide' the room in half with couches, etc. What receiver do you recommend for this setup? I've looked at: Harman Kardon AVR 330 Denon 2803 Onkyo 701 Integra - not sure of the part number) Panasonic xr45 What do you think? |
Silver Member Username: Edison
Post Number: 352 Registered: 12-2003
| Posted on Saturday, February 07, 2004 - 05:36 am: |
Panasonic xr45 - sounds smooth and clean with a great bass like an upscale piece - and only $300. |
Silver Member Username: Hawk
Post Number: 224 Registered: 12-2003
| Posted on Sunday, February 08, 2004 - 02:57 am: |
Mgrennier: Those Omnisats are what aI call a very "hot" speaker--that is, they are very detailed and even bordering on bright, but they are wonderful to listen to with the right electronics. I think they are a very good choice. I would defintely get the H/K from your list. It is the warmest sounding and has the best power supply (H/Ks always put in quality power supplies, unlike most receiver makers). It also has a slightly laid back sound that will take the edge off of those OmniSats, without sacrificing their wonderful detail. I have heard this combo and it really works well. Good luck! |
| Posted on Sunday, February 08, 2004 - 10:23 pm: |
Hawk, James. Thanks for your advice... I think I'll go with the H/K... Mike |
| Posted on Sunday, February 08, 2004 - 10:32 pm: |
Mike, Hawk really knows his stuff. Believe in him. I do. Go with the H/K. The omni's are great looking. |
