Thread: Conversions with Home Audio on Sub. Help! |
New member Username: Eternaltrancex2
Post Number: 1 Registered: 02-2004
| Posted on Thursday, February 05, 2004 - 09:09 pm: |
I have a slight problem. My stereo have one connection for a subwoofer. It's black female RCA connection. The subwoofer I have uses the red and black speaker wire connections. How do I hook these up? |
Bronze Member Username: Unicronwmd
Post Number: 77 Registered: 12-2003
| Posted on Thursday, February 05, 2004 - 11:17 pm: |
Either one single RCA cable from the black RCA jack on the receiver to either one of the inputs on the sub. Or you can get a Y connector to hook the single RCA cable to both of the RCA jacks on the sub. |
Post Number: 2 Registered: 02-2004
| Posted on Saturday, February 07, 2004 - 01:07 am: |
The Sub I have uses wire connections, not RCA. |
Post Number: 82 Registered: 12-2003
| Posted on Saturday, February 07, 2004 - 01:55 am: |
Sorry man, I think faster then I read Ok, connect 2 speaker wires to the receiver's main speaker out-puts and have them hooked up to the sub's speaker wire in-puts. Then take 2 speaker wires connect them to the sub's speaker wire out-puts and hook them up to your main speakers. Hope that helps. |
Post Number: 3 Registered: 02-2004
| Posted on Sunday, February 08, 2004 - 01:08 am: |
Well I tried that with my Sub but my Sub does normal sound too now. But im not using that sub. Im using a sub that only has 2 wire connections for input only. I have no output connections to send the sound to my main speakers. Is there a way to take a RCA plug a splice it to make connections for red/black? |
Post Number: 4 Registered: 02-2004
| Posted on Sunday, February 08, 2004 - 01:10 am: |
Getting hard aint it? =\ |
Post Number: 83 Registered: 12-2003
| Posted on Sunday, February 08, 2004 - 07:51 am: |
No you can't use the RCAs because it sounds like your sub isn't powered. I say if you really need to use THIS sub. Connect it to the B channel speaker connections on your receiver. So the front speakers would be on the A and the sub would be on the B channel. |
Post Number: 5 Registered: 02-2004
| Posted on Sunday, February 08, 2004 - 04:22 pm: |
Now im really lost |
| Posted on Saturday, April 24, 2004 - 09:51 pm: |
I have a similar problem. I want to replace the speakers on my cheap disk changer which has traditional 2 black/2 red speaker wires, by channeling it into my surround sound. I know I will only get sound from the two front L/R channels but I really want to replace the big old speakers. How do I switch from the 4 red/black wires to either rca or 1/8" adapters? Thanks |
Unregistered guest |
| Posted on Thursday, May 20, 2004 - 07:27 am: |
want to use a passive x-over for 12 sub in home to get more bass think it will work |
ken.j.white Unregistered guest |
| Posted on Saturday, August 21, 2004 - 09:40 pm: |
Ok here is the correct answer, go to radio shack buy a RCA to script wire cable they come in 24' and 12' 2.99 and 6.99 ... Plug the RCA end in your amp and the wires to your speaker |
