Home > Message Board > Home Audio > Amps > Archive through January 27, 2005 > I need help
Author Thread: I need help
Username: Carey42
Clarksburg, West Virginia
I have 3 MTX 10" subs and i needa know what size amp i should use to push them...i have a 450 watt audio lighning amp right now and im not sure if its enough power...what should i get???
I need to know what series they are
EX:6000,8000
to give you an answer i need to know what series they are
EX: 6000,8000
Username: Carey42
Roadthunders
are they dual voice coil
Username: Carey42
yah...dual voice coil
Username: Carey42
u can i.m. me at bbball4life04@aol.com...or email me to make this a lil faster
k know are you looking to buy a new amp or you want to use the old one?
with all the subs wired into series it should be 2.7 ohms
And the amp you need has to have a max of 600rms
into 2ohms
Username: Carey42
if i can use the old one i will...but if i needa get a new one i will...so..b/c a new amp will cost sum money id like to b able to use the old one...but if not i need to know what to get so i dont waist my money
I dont think the amp you have is 2 ohms stable
if you decided on getting a new amp i recommend the MTX THUNDER801D
500 rms into 2ohms at 12.5v
Username: Carey42
how many watts???
500 watts rms thats all the time going to the subs
into a 2 ohm load witch your subs will almost produce to the amp
Home > Message Board > Home Audio > Amps > Archive through January 27, 2005 > I need help [ « Previous ] [ Next » ]
