Thread: Paradigm vs. Definitive Technology vs. Totems |
New member Username: Thereal_1_
Post Number: 3 Registered: Nov-04
| Posted on Monday, December 27, 2004 - 12:30 pm: |
Hello, I recently upgraded my receiver to the Yamaha RXV-1500 thanks to the feedback on this forum. I'm now thinking of upgrading my main front speakers and have narrowed down to 3 of them based on a budget of about $1,000Cdn ($800US). My current setup is all Paradigm: Front: Titants on stands, Rear: Cinema 90, Center: CC-170, Sub: PDR-10 I was planning to go with Paradigm Monitor 5/7 but decided to spent a little more to get a higher end product. Which of the following speakers would offer me the best value for the bucks and or be the most suited for my setup? I have listened to them all at the show rooms and have mixed reviews. They are: - Paradigm Reference Studio 40 ($1,000 Cdn) - Definitive Technology PM 500 ($950 Cdn) - Totem Accousitc Arro ($1,100 Cdn) If there are any other speakers in the same class should consider, please let me know. Thank-you all in advance. Brad |
Bronze Member Username: Cornelius
Post Number: 83 Registered: Jun-04
| Posted on Monday, December 27, 2004 - 04:41 pm: |
Ohm Acoustics Microwalsh Tall. I auditioned all of the above but I like the Ohms better by a large margin. They are a little more expensive, but I found the investment worth it. |
