Home > Message Board > Home Audio > Amps > Archive through January 27, 2005 > BI-AMP or PRE-AMP with Arcam Alpha 9p...
Author Thread: BI-AMP or PRE-AMP with Arcam Alpha 9p power amp
Username: Stifa
Post Number: 19
I'm sure many of us want to know this, so please if someone had experience with this please help:
I have Alpha 9 powr amp, WHAT IS THE BEST SOLUTION:
1) To buy integrated amp (DiVa A65+) and use it together in bi-amp system,
2) To buy PRE-AMP(NAD C162) and use it as pre/pwr
3) (most expensive) PRE-AMP and two power amps for BI-AMP.?
I am interested what are differences between these choices, mainly the first two, and which is the best.
Is separate PRE that better than one in integrated?
Please reccomend some other equipment if you know it works well.
Speakers to go with this system will be Wharfedale Evo 20.
THANKS
Marko stifa@eunet.yu
Home > Message Board > Home Audio > Amps > Archive through January 27, 2005 > BI-AMP or PRE-AMP with Arcam Alpha 9p... [ « Previous ] [ Next » ]
