Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through December 29, 2004 > Definative Technology StudioCinema
Author Thread: Definative Technology StudioCinema
Username: Turbogti
St. Andrew, N/a
Jamaica
Post Number: 7
Definative Technology StudioCinema 350 System or StudioCinema 450 System.
I think i've come down to one of these systems, but before i proceed i have to ask you guys what are your thoughts on these speaker systems.
My reciever will be a HK AVR 235
Are these speakers a good match for the HK or should i go back ot the drawing board?
Username: Project6
Post Number: 2229
How did you like it? If you liked the way they sound, that should be enough.
Username: Project6
Post Number: 2230
oops, forgot to add. The Studio Cinemas are great sounding speakers and should match well with the HK.
Username: Turbogti
St. Andrew, N/a
Jamaica
Post Number: 8
Benny the Studio Cinemas 450 that i heard were great, they didn't sound as if they were breaking up when the guy turned the volume up on the opening sequence of Riddick.
The Supercube Sub was shaking the glass door.
I believe that the 450 is more than what i need for my little room but i wanted to check you guys first and hear what reviews you had with these units.
Thanks for your REply Benny.
Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through December 29, 2004 > Definative Technology StudioCinema [ « Previous ] [ Next » ]
