Thread: HELP!!!LYRA-JUKEBOX RD2825/2840!! |
New member Username: Alainamarie
N/a,
N/a
United State...
Post Number: 1 Registered: Dec-04
| Posted on Saturday, December 25, 2004 - 10:47 am: |
Help Please! When I plugged it in, nothing happened. It says to let it charge for 4 hours for full use and 30 minutes for minimum to no use but nothing has happened. It has been plugged in for an hour or more. PLEASE HELP! THIS WAS MY BIG CHRISTMAS GIFT! |
New member Username: K0ss
| Posted on Saturday, December 25, 2004 - 08:00 pm: |
Im having this same problem, if anyone knows how to fix this please reply and let us know! Thanks... K0SS |
| Posted on Saturday, February 05, 2005 - 01:25 am: |
Mine won't turn on either and I don't know what's going on? Help!!!!!!!!!! |
| Posted on Thursday, February 24, 2005 - 11:01 pm: |
Have you tried the reset switch accessible through the small hole in the left side of the case? I have a non-functioning power switch (probably due to the bath the unit took :-() but the reset button usually wakes the unit up.
Bronze Member Username: Jesuspunk25
Post Number: 29 Registered: Jan-05
| Posted on Tuesday, March 01, 2005 - 12:00 pm: |
I would recommend resetting it, I just got one of these and it powered up immediately so if resetting it doesn't work I would contact rca about it. |
Unregistered guest |
| Posted on Tuesday, April 05, 2005 - 12:42 pm: |
mine won't connect with my pc. it on it running but it says theres no plug in connected |
