Thread: SMALL ROOM. What kind of speakers?? |
WILSON94 Unregistered guest |
| Posted on Tuesday, December 21, 2004 - 11:15 pm: |
Hi I am looking to upgrade my speakers for my home stereo that is located in my room, fairly small sized room at about 16 X 12 feet. I have been powering a large pair of 250 watt Audio Tech(no-name) speakers but I am fed up with the poor quality of sound. I have a NAD amp that pushes about 100w/c, and was hoping somebody had a suggestion of speakers, either a bookshelf pair or a floor model. I listen to hip hop/rap music, and LOVE BASS! Thank you. |
Silver Member Username: Kano
Post Number: 213 Registered: Oct-04
| Posted on Wednesday, December 22, 2004 - 01:27 am: |
I'd get some moderately priced speakers with a good powered subwoofer. Since your room is small you may want to look at bookshelf speakers on stands. and this subwoofer - http://www.svsubwoofers.com/subs_pci_20-39.htm
Post Number: 2187 Registered: Dec-03
| Posted on Wednesday, December 22, 2004 - 01:29 pm: |
What is your budget on speakers? The SVS sub suggestion will feed your appetite for bass |
New member Username: Redwolf1978
Chtown,
PE
Post Number: 4 Registered: Dec-04
| Posted on Wednesday, December 22, 2004 - 02:36 pm: |
I would go for the Polk RTI4's paired up with a PSW10 sub. |
Post Number: 217 Registered: Oct-04
| Posted on Wednesday, December 22, 2004 - 05:24 pm: |
That PSW10 has a really high bottem bass extension and only 100W RMS. I was going to add that stepping up to the SVS PC-Plus gives you another 200W RMS power. http://www.svsubwoofers.com/subs_pcplus_20-39.htm
| Posted on Wednesday, December 22, 2004 - 08:16 pm: |
Check out PSBs line of speakers, JM Labs Chorus line, Quads .... kinda depends on your budget... these are reasonably priced great sounding speakers. -Rick |
