Home > Message Board > Home Audio > Equalizers > Equalizer
Author Thread: Equalizer
Does anyone own a Realto home theater equalizer?
If so, is it worth the money? does it perform well? I'm very interested in purchasing one but not before i hear from you folks. Thanx!
Relevant Product Info
hskpr1
Sorry. It's spelled Rialto.
nsn
I just bought a pair of used speakers. The brand is Linear Phase.Does any one know about this brand? The power rating is mentioned as 150 W. I do not believe it can handle that much. The drivers do not have any details on their backs.At moderate volumes it sounds quite good. But rattles a little at higher levels. I have hooked it up with a Pioneer SA 6700 which is said to deliver 40 W per Channel. Also anybody have the specs of this amp?
Username: Numarkeq2600
Lyons, Il
Usa
HELLO CAN ANYONE HELP WITH THE INSTALLATION OF A NUMARK EQ MODEL 2600 TO A PIONEER A/V RECIEVER????
Lyons, Il
Usa
MY EW HAS 2 SETS OF OUT PUTS (OUTPUT 1 R+L, OUTPUT 2 R+L) (TAPE OUT R+L) AND TAPE MONITOR R+L)
AND AN OUTPUT R+L CHANELS
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Equalizers > Equalizer [ « Previous ] [ Next » ]
