Home > Message Board > Home Audio > Integrated Amps > Archive through November 19, 2004 > Pioneer A402 int. amp questions
Author Thread: Pioneer A402 int. amp questions
Username: Creed
Post Number: 23
i have one Pioneer A402 int. amp, recently i take it and use it, i notice when i turn the volume dial, there some hissing caming out from my speaker, i think the volume dial on this int. amp having some problem, but i just want to know whether it will spoilt my speaker, since now i am using it now for my music playback...and connected it from my receiver's front channel pre-out...thanks
Username: Gman
Post Number: 161
Sounds like the volume control needs cleaning on the metal part. It will not spoil your speakers--screaching tones are often blasted from speakers during adjustment.
Now the sound may be coming from a problem in the speaker. But I'd clean the volume control connection first and if that doesn't work, borrow another speaker to see if it is the speaker--or borrow another integrated amp to see if that works fine,
If you still have the problem take your amp to the dealership or local electrician if it is under warranty). If not under warranty still take to dealership/electrician and see how expensive to fix. If it is--buy something new.
Username: Creed
Post Number: 25
i tested on my receiver, there is no hissing...screaching tones at all, as i said, the int.amp only produce this when i turn the volume...if i never turn the volume, the sound is clean and clear...
Username: Gman
Post Number: 162
as I said--sounds like the volume control pot connections needs cleaning. If it doesn't help take the amp to an electrician (preferably one that deals with your brand)--you may need a new volume control pot.
Soma
Hi!
Where can i download a manual for this amp?
please send me a link!
somogyil@ntszki.hu
Home > Message Board > Home Audio > Integrated Amps > Archive through November 19, 2004 > Pioneer A402 int. amp questions [ « Previous ] [ Next » ]
