Home > Message Board > Home Audio > MP3 and Digital Audio Players > Archive through March 21, 2006 > Help!: RCA Lyra 2840 - Unable to
Author Thread: Help!: RCA Lyra 2840 - Unable to
Username: Musik05
Woodbridge, Nj
Usa
After I copied couple of files on Lyra 2840 via PC, it stopped working. Several minutes after the on button is pushed, there is message - "Failed to load system files. Reload LyraHD system files"
Please help!! Thanks in advance.
Mountie68
Go to the RCA web page and bring up audio devices then downloads and look for lyra 2840 downloads then reload your system files via your usb.
jwhip05
When i put some music on my RCA LYRA 2780 it said I had a corrupted system flies and then shuts off.
I tryed udating system flies but it still dosnt work. HELP
KDog1800
I can't even reload the 2850a's system files because my machine won't recognize it anymore. Can anyone please help???? megamanx18@yahoo.com
Username: Blindman
for manoj and jwhip05 all you need to do is update your firmware. your system files basically got corrupt. Should work fine after that.
KDog1800 chances are the device is "still attached to the computer" meaning, if you are in windows xp, the device needs to be removed from the taskbar "safely remove hardware" icon... i would uninstall and reboot, then obviously reinstall the software from the site...
Best of luck to all
Username: Squirlzmm07
my files were corrupt, and it still has corrupt files, please help
sjensen@mountmichael.com
after i updated my firmware they were still corrupt
I had an error loading files onto my lyra 2850a, and now my computer does not recognize my lyra as being connected to the computer. Someone had talked about the safely remove hardware icon in the windows xp taskbar, but I can't find that. Please let me know how I can resolve this issue.
Home > Message Board > Home Audio > MP3 and Digital Audio Players > Archive through March 21, 2006 > Help!: RCA Lyra 2840 - Unable to [ « Previous ] [ Next » ]
