Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through February 12, 2004 > Matching speakers
Author Thread: Matching speakers
Username: Sjordan872
One more ? everyone. When matching speakes (from the same line of course), is it more important to have the same size tweeter or same size woofer? Thanks again!
Kal
Not really, just make sure you buy the top of the line center channel in that line. Most of the tweeters in all lines are the same; usually one inch, however the woofers get bigger as do the price. Hope this helps.
Username: Elitefan1
Post Number: 174
Most manufacterers make specific centers to match specific mains. Follow their recommendations and you can't go wrong.
Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through February 12, 2004 > Matching speakers [ « Previous ] [ Next » ]
