Thread: Bose Companion 3 ??? |
New member Username: Lmbear
Post Number: 7 Registered: 01-2004
| Posted on Tuesday, January 27, 2004 - 11:41 pm: |
I just purchased Bose Companion 3 speakers for my computer. I heard them in bestbuy and thought they sounded pretty good. I had a $120 gift certificate to Brookstones burning a hole in my pocket and decided to buy them without much research. They are still in the box and I am debating whether or not I want to keep them. Does anyone have any advice? |
New member Username: Edison
Post Number: 333 Registered: 12-2003
| Posted on Thursday, January 29, 2004 - 05:44 am: |
I would return them and get the Athena AS-B1. Much better sounding - won the best speaker under $200 in many hifi sights. Unlike Bose, you can listen to it for a long time without getting tired of the sound. If you add a sony sub sa-wm200 or 500 (better) at www.etronics.com, sounds even better for not much more. |
Post Number: 8 Registered: 01-2004
| Posted on Thursday, January 29, 2004 - 08:28 am: |
Thanks for the info. I read some reviews on the Athena speakers and the look great. The only difference is, that if I keep the Bose I only $80 bucks comes out of my wallet. I just bought a Sony 50" Grand Wega and my wallet is extremely tight right now. SO if I do upgrade the speakers, I am probably just going to return the BOSE to brookstones and hold off for a while. Thanks for the help.
