Home > Message Board > Home Audio > Cassette > Need a code for Cass Philips Car 400
Author Thread: Need a code for Cass Philips Car 400
Username: B_bog81
Please help! I need a code for my cass (Opel) Philips Car 400 ( model: GM 90506173, PA6-GF15, 1614438 Philips). Baba_Bogdan22@yahoo.com if anyone know the code ! Thanks
please help need code for my car (opel vectera)
i don' find my cade member for my radio cassette
pilips car 400
because my batérie is deed my radio need a code for 4 number
pilips car 400
How do you put in the known code into a Philips S200 car radio, Please!
gian52
aiuto!!!ho dovuto staccare la batteria ora mi tovo con l'autoradio car400 :leggo 7safe ed e' bloccata no riesco ad inserire il codice a 4cifre in mio possesso
sicuramente devo aver sbagliato
si puo' resettare? come? moltissime grazie
anticipate
Ho comprato una Opel corsa usata ma non sono riuscito ad avere il codice della autoradio montata, una Philips DC 247, e non posso quindi utilizzarla. Qualcuno può essere di aiuto?
Grazie in anticipo.
Hi there!
I've got a problem with my Philips CAR 400. As usual for this radio I lost my RADIO PASS and so the CODE to unlock the radio.
Who can help me? The S/N is GM0400T1449138. Other numbers on the bottom of the radio are No.: 90 532 621, 2F3, the Barcodes: 9022 213 96752 00 and 003 9651 1449138.
Please help me.
Regards
Claus
Hi there!
Please help me.
Regards
Claus
ankur
Anybody knows free site for code of phillips car 400
Santas little helper
http://radiocode.proboards6.com
Should help you all
i have philips 400 car radio. i swich off from the battery and now i can`t restart the radio. please tell me how to enter the code and establish the radio again?
michal
my radio has code 0635. hope it'll help.
ADY GRIFF
Hi,HELP
I need some help with code for my philips car 400 the number is GM0400Y2823452 I have lost the card with the code on .OOPS.
my radio number is GM0400Y2859189- code reqd if possible
Username: Koma
Belgrade, Belgrade
Serbia
Hi all
I have a question to ask...
I need a radio code for my Philips car 400 out of a Opel Vectra 98
NO 90532621
Type car 400
2F3
I also have a number on back of my radio:
WA019727
please help i need it very much!!!
thanks!!!
thanks!!!
thanks!!!
I need an unlock code for a Philips RDS model 22RC200/35 the serial number is PHACFFX9037865.
I would be most appreciative forany help
Hi all
I need a radio code for my Philips car 400 out of a Opel Vectra 99
NO 90532621
Type car 400
2F3
WA049937
GM0400X2512326
please help, thanks!!!
Hi there,
If anyone can help I would be eternally gratefull. I have a Philips CAR400 Taken from my mums Vauxhall Astra Estate.We had to disconnect the battery, and so lost the code.
the number on the side is:
GM0400X2569162
the 2 barcodes on the top are:
90222139975900
00399422569162
I tried other sites, but they couldnt find the code.
Thanks in advance!
hey i need a radio code for a phillips 400 code number thing is GM 90506173 cheers :-)
Have a phillips CAR 400. Please advise where to find the S/N.
hi :-) my old opel corsa have a battery low, and the Philips Car400 is in "CODE" security.. the radio have a 1st barcode 9022.213.96752.00 and 2nd barcode 003.9645.1419070, another number GM0400T1419070 and another DC396/75E 2WA00 29.10.96
please what is a right security code?
Username: Gioma
Hallo,
I changed batteries on my Opel Vectra and the radio asks for the code. can't find it any more.
Car dealer asks for payment to give me the code again :-(
Model No 22 DC 347/78
Prod. no. FD 0997459057702
aszxqw at libero dot it
Hope you can help, thanks
Gioma
Bicska
I think you need this:
http://www.eserviceinfo.com/downloadsm/18226/_.html
rafi
Hi,
I also need code for my radio.
I've had the LPG installed in my car and they had to disconnect the batery
My numbers:
GM0400W1930886
It' Philips CAR 400
90 532 621
WA029819
I appreciate any help.
Thanks
Rafi
Jokerrr
How does that Calculator works?Has anyone downloaded it? Does it really works?
An other one?
I've just put it back before solding it tomorow afternoon... but I had never had this f...ing code from Renault!!!!!
So, I'm searching for RN593FV4127888 code
Philips 22DC593/62L
very very big thanx
barney gumble
Hi
has any one got a serial number for a
phillips audio 4030
sn. phapbfv9102007
many thanks
Username: Maristez
please Can anyone let me know about an code for radio Philips
car 400
GM0400V1541813
Hi , How can I input code when on display is message
7 CODE after I press AS and switch on radio.
Can anyone help me what I must do ??
THX
ould i have a code for a Philips car 400 please
No.90532621
BarCode 1 : 9022 213 96752 01
BarCode 2: 003 9728 1674631
GM0400V1974631
radio-code.co.uk
I can decode Philips, Grundig, Blaupunkt, Ford, Clarion, Delco.. YES DELCO CDR 500..
All instantly, no waiting days for a code, instant via my site with 100% money back guarantee.
www.radio-code.co.uk
needto decode my car radio. phillips sc201
i changed my opel corsa's car battery and cant decode it its a phillips sc 201
Tante heiter
German User use http://stsboard.de
Hi,
Does anyone know the code for a Clarion Finish Line 540 Radio cassette player?
Its in a K - reg Mazda 323F and the code is long gone.
Any help would be greatly appreciated.
Thanks in advance,
Best Regards
Anis
hi my friend as just brought a stereo off someone and im trying to get the code for him if u can help then that would be great.....its for a car400....the only code i have is 90462560
thanks in advance if u can help :-)
NEED CODE PLEASE
hi philips radio from laguna serial RN9B2FS1013664 MY DAD DISCONNECTED THE BATTERY DONT HAVE THE CODE WOULD BE VERY GRATEFULL IF ANYONE COULD HELP WITH THE RADIO CODE THANX DAZ
Please Please Please can anybody help me. Does anybody know the seucrity code for a Delco Electronics CDR 500. My battery went dead the other day and locked the stereo with my CD inside and now I'm lost without my music. I'm talking to myself in traffic. If anyone can save me from insanity and give any tips or codes to solve my problem I'd really apprciate it...
Thank you
soks
hi i have lost the code for my car radio and now need it again since attempting a refit! its in a fiat punto and the radio just says fiat though im guessing its a philips by its serial number: PHF011V4015497- Stamped on the side. ive wasted money on programmes that dont work - can anyone help!!!!
there are other nos on white label:22DC449/64L
9022 214 49644
M/ch 015345
Hi guys,Please i have need yours help,i need the password por a Blaupunkt rds,serial no ptn 90336222021
Thank you vvv much
Username: Elbart
Magliano alpi, Italia
ho un autoradio philips dc247 ...ho perso i codici di aviamento sono disperato non posso gia buttarla via
aiutatemi!!!!!!!
Denys G Froehich
Any Vauxhall dealer will help with this (for a fee) if you can prove ownership
Username: Marco_pearson
Hi, I'm looking for a Philips car stereo code please. I'd be really grateful for some advice - my friend has taken it out of her car and given it to me but with no code!!
The model no is 22RC200/65
Prod no FD1002249382236
and there's another number: PHAPKF29382236
Can anyone help me please?
Stuck
I have the code for my Philips SC 201 radio, but don't know how to enter it in! Does anyone have the instructions? The radio came out of a Vauxhall Corsa if that helps! Thanks.
Please help! I need a code for my cass vauxhall (opel) Philips Car 400 ( model: GM 90506173, PA6-GF15, 1614438 Philips). grieveshane@hotmail.com if anyone know the code ! Thanks
Please help! I need a code for my cass vauxhall (opel) Philips Car 400 ( model: GM 90506173, PA6-GF15, 1614438 Philips). grieveshane@hotmail.com if anyone know the code and access instructions too ! Thanks
cat11
Hi i need code for philips car 400 (opel) serial number: gm0400x2569942
I can't find any solution anywhere, please help me!
cat11@poczta.onet.pl
i have a vauhall vectra 2001 make and need a code to work the cd player
only code i have is GM 24465993
Username: Fuzzi
I need pls code for siemens PA6-GF15 GM 13 107 918 , i change a battery and i cant decode it
can you help me??? Thanks
Blazej
The serial number is engraved into the side of the radio not on the removable panel.
It will be 14 digits long i.e
GM0400Y1234567
I can decode most of these via my website www.decoderz.com or you can send them in for decoding. See my site for info and fees.
Username: Sirmada
Hello!!
Need code for my Philips Car 400
Serial nr: GM 040011268112
No.: 90512304
Thanks
Username: Sirmada
Hello!!
Serial nr: GM 0400T1268112
No.: 90512304
Thanks
Username: Vgrobben
Hi
I'm looking for the code for my philips car400.
GM0400W2055404.
Thanks
Username: Markfa1
Hi
I am looking for the code for a philips car 400 cassette player.
Serial number : 9022 213 96752 03
if you need any further info. email me please
Plus need to know how to insert the code
Username: Vollga
Worms, Rheinland-Pfalz
Germany
I bought an Opel Corsa B last week with a philips SC-201 car stereo radio, but without any code. Have anyone a program to find the number? Here are radio`s data:
Philips No: 90 381 124
Type SC 201 (C) W1B
Barcode 1: 9022 214 60758 02
Barcode 2: 003 9503 1601075
Thanx a lot for your help!
Username: Vollga
Germany
Sorry, GM-Number is GM0201S1601075
Username: Muxxa
I have a Phillips DC 349/1 PA. I disconected the battery to do a maintenance in the car. I made a mistake when I put the code, And now an Err message is appear in the Display. Please, somebody know how can I do to put the code again?. Thanks.
Username: Muxxa
sorry, my e-mail is maxib@planex.com.ar
Username: Markfa1
I would like to thank members sending me emails about my phillips car 400 radio. I have now got the code from a source on the web. Code was 4558 thanks again
Username: Bjain
I have recently bought a N reg Rover 214SLI 4 door saloon car. The car was unsed for last 7 months and battery was dead. The radio therefore, branded ROVER, asks for code with orange dispaly showing -C-. Can someone suggest a number I need to enter. It is a 4 digit number. The previous owner did not have the card which had radio code and also immobiliser code.
Here are the details of the radio/cassette.
Type 22 DC652/60E
RG part no. XQD 10056
FD 01 94 50 2477431
Serial number on metal work RG 652FR2477431
Made by Philips but branded ROVER.
I can prove ownership of the car if someone needs to know that. Please reply to bjain@rocketmail.com
Username: Nukem_bbs
Hi there! Please, help me to find the code for Philips Radio in my Peugeut 406. This is what can be found on it:
96 336 890 2L 00
PHI1091327
model no: 22DC594/65B
piod no: FD 0299041091327
6/00950/19060/A
DM 25-6-1985
DM 27-8-1987
and on the side: PHAPIFX1091327
makes any sence? Cheers!
Username: Radiocodes
Post Number: 18
ENGLISH :
http://www.radio-code.co.uk/?lang=eng
GERMAN :
http://www.radio-code.co.uk/?lang=de
Username: Houdanii
Hi there!
help me to find the code for Philips car400 Radio
90 532 621 2F3
GM0400W2087917
and thaks for help
Post Number: 25
INSTANT ONLINE RADIO CODES 24 /7
ENGLISH :
http://www.radio-code.eu/?lang=eng
GERMAN :
http://www.radio-code.eu/?lang=de
FRENCH :
http://www.radio-code.eu/?lang=fr
Username: Gartdesign
Kikinda, Kikinda
Serbia
I NEED A CAR CODE FOR PHILIPS CAR 400
GMGM0400W1958338
PLEASE HELP, THANKS
BRANISLAV
OFFICE@GART.CO.YU
Username: Willieman
PR
Username: Lesternaylor
Leicester, Uk
England
hi need a code for phillips car 400
no.90532621
Type. Car 400
Other No's 90222139675204
00399072242437
Username: Dmcnan
I need the code for a Philips 400 car radio. It is a second hand car and I do not have the code number. The numbers on the back are 1 614 438, GM 90 506 173, and PA6 GF15. Any help is appreciated.
Username: Benboi
need a code for a phillips car 400 , the serial number is gm0400x2266331
theres another number which is 90532621
anyone can help it would be much appreciated
Username: Acdcadaptor
philips car 400 code need
serial: gm0400x2484946
Username: Pirx
Hello I have a question about code to the radio Philips 400 GM 90506 173, >PA6 - GF15< (1 614438) from Rover. Thanks!
Post Number: 65
Codes available online and can be sent by sms to your mobile instantly from www.radio-code.co.uk
Username: Paweljur
need a code for a phillips car 400. It is a second hand car and I do not have the code number. The serial number is GM0400T1252331
theres another number which is 90462560
Pawel
paweljur@wp.pl
Username: Niflettica
Have found a copy of CAR 400 Radio by Phili[s onlione at:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem%26item%3D180038809628
it tells you stuff like howto put in your code, adjust security etc
hope this helps
Post Number: 67
Why buy that info ??
Its available FREE on my website : www.radio-code.co.uk
Click below for instructions :
http://www.radio-code.co.uk/post_in_radio_code_model_selection.php?m=Philips
Have found a copy of CAR 400 Radio by Phili[s onlione at: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem%26item%3D180038809628
Username: Amitsb
Bought 2nd hand Clio but with flat battery and its asking for the code,
I pulled out the radio and the serial numbers are as follows
Model No: 22DC259/62F
Serial No: RN259FY0244021
Your help in finding the code is much appreciated...
Thanks in advance
Amit
abhawalkar@hotmail.com
Username: Ukbigd
Roki.
Try This, Let Me Know If It Works.
6ca8 hit OK Code = 1234
Post Number: 69
Roki.
Hi David..
I think Roki wanted the code from serial not by reprogramming the eeprom.
Username: Szylwius
Hi!
I would really appreciate it if somebody could find me a code for a Blaupunkt radio (Opel Corsa), the type is Car 300 (D), and the no. is 90 532 620 (on the bottom there is also a specification 2F2). Thanks in advance!
Username: Tripole
Libya
Dear Sirs,
I'm looking for code for my Philips CAR 400 for Opel Astra /1999.
The number on the case is GM 90 506 173 <pa6-gf15>
(1 614 438 PHILIPS) and no. 90532621 type car 400 2F3
Made in Germany
Can you help me ,please ??
Thanks & Best Regards,
Username: Tripole
Libya
please what happened to my request?
thanks
Post Number: 81
This forum isnt ACTIVE, and requests for free codes are not being actioned by me....
http://www.car-audio-accessories.co.uk
Username: Lornaallan
Hiya there,
I am desperately trying to find the code for a Philips Car 400 stereo. The serial number is GM0400X2426407, the car is a Vauxhall Astra. Other numbers on the radio are 90222139675204 and 00399252426407. Any help greatly appreciated,
Thanks,
Lorna
Post Number: 83
Hi Lorna
Your radio code is not listed in the early Philips database so unfortunatly you wont get it from any forum.
You can either try Vauxhall Direct or, as you are aware we can also obtain it for you.
Username: Zozi80
Hi There,
Could you please help me? I need a code to unlock my car radio (Philips 22DC593/62L)
The snr is: RN593FT4048779
Thanks in advance
geigerzoli@freemail.hu
Username: Deltaone
Hi There!
Need a code for my Car 400
heres the gm code:
GM 040023295985
Username: Touroless
hi I need opel vectra code car400
NO 90532621
2F3
GM 90506173
my email touroless@stcable.co.yu
thx
Username: Biofa_df
Gama, DF
Brazil
hi I need GM vectra (Brazil) code cdr 500
NO GM0500V0009683
GM 93274400
my email biofa_df@yahoo.com.br
thx
Username: Ladiely
Makati, Metro manila
Philippines
hi there!!!
can u help me???how can i connect my ipod into philip s car 400 opel astra????is it possile???
pls let me know!!!!!
Username: Ladiely
Philippines
hi there!!!
can u help me???how can i connect my ipod into philip s car 400 opel astra????is it possible???
Username: Nowikp
POLAND
please give me code for radio car400
GM 0400x2595751
Thanks
toudip@wp.pl
Username: 441
I need some help
I bought a car from an old woman and cuz of changing the bat now the carradio ask me for the code, but she never gave it to me
It says 401 in the front and DC441AL in the back, the reference number is A5317 and the number carved on the metal is 699983
How can i get the code number without paying? Thanks!!!
Username: Duki2007
Suhareke, Kosovo
Kosovo
Hi all
I need a radio code for my Philips car 400 out of a Opel Vectra `99
NO 90532621
Type car 400
WA039842
d_haziraj@yahoo.com
thanks!!!
Username: Duki2007
Suhareke, Kosovo
Kosovo
Need a code for my Philips Car 400 PLEASEEEE...
GM0400W2121046
No: 90532621
90222139675203
00398422121046
d_haziraj@yahoo.com
Thanks...
Username: Duki2007
Suhareke, Kosovo
Kosovo
Need a co de for my Philips Car 400 pleaseeee...
GM0400W2121046
No: 90532621
90222139675203
00398422121046
E-mail: d_haziraj@yahoo.com
Thanks in advance
Username: Krisw
hi
need a code for my radio philips DC594
No:RG594FW2196540
many thanks
Username: Krisw
my e-mail:kwysocki5@wp.eu
Username: Gustjar
hi all. could someone help with what seems, after reading this forum, a common problem. I need the unlock code for a philips car 400 vauxhall please. the numbers on the radio are 24455379,90222139975403,00302283250159,wa030228. any help will be greatfully received.
if possible could someone reply to my email triplebben@googlemail.com
Username: Afisse
I need the code for Philips car 400, zafira 2001
GM 90506173
PA6-GF15
1614438
Thank you
yoann211@aliceadsl.fr
Username: Car400
I have a CAR400 stereo and when got some work done my battery was disconnected and now i have no code can you help?
my S/N is GM040013078235
Username: Mido_333
Cairo, Cairo
Egypt
car400 code plz
Username: Jimmyjimmy07
Please help, i need a code for a Car 400 s/n gm0400y2744603, i've found some software but not sure how it works, thnaks for any help. jknightley@ntlworld.com
Username: Silviu126
i need a code for philips car 400 GM0400v1662589
silviu.opritoiu@yahoo.com
Username: Silviu126
need code for phiplips car 400
www.sofshop.ro
Username: Kicker1s
Hello. I need code for my Philips car400.
GM0400V1725354
GM90506173
PA6-GF15
1614438
Thanks !
Username: Kicker1s
my e-mail kicker1s@inbox.com
Username: Reef86
Trinidad an...
hello, i own an Opel Vectra 2002
I changed the ECU unit in the car and since then my sterio is locked up. Anyone know how to crack codes or know how to get codes? it's a
VDO
PA6-GF-15
GM 13 107 918
Please help. Life is boring in traffic
Thank You!
Username: Deamer_16
hi i have a philips car 400 its out of my 2001 astra, the battery recently went and i am now requiring a 4 digit code, and i have lost my radio pass. can anyone help here is my s/n:GM040012981494
other numbers on the radio are no: 09 136 106
326559176 2F3
then there are 2 barcode numbers
90222139975601
00301012981494. cheers help would be much appreciated.
Username: Deamer_16
sorry more numbers on my radio are also
1 614 438
GM 90 506 173
PA6 GF15
cheers.
Username: Dk_sain
Please note that we have philips car stero in our opel astra model No. 22DC 347/78 product No. FD 0697089036167 Sr. No. IL01 009325
We need the code to activate the stero
Username: Randyraji
hi here. i hope someone can help me get the code for my philips 400 car. i have removed it and found the serial no. gm0400w1820229. other numbers i can see are 90 532 621, 2F3, bar codes 9022 213 9752 01 and 003 9803 1820229. it's from a corsa. i hope to hear from someone soon. thanks in advance, Rob
Username: Grabonis
hi.please help mee.i need code for my car opel vectera radio.
codes:
1 614 438
gm 90 506 173
>pa6-gf15<
big big big Thank You!
my e-mail is rs3@inbox.lv
Username: Reef86
Trinidad an...
hey folks...you know normally your secuity codes comes with the car on a lil piece of 'call card' sized card. normally it is be in the glove compartment. but when i bought my Opel Vectra it was a used car from someone else who didnt even know what they did with the card with the unlock code. all i did was call up the Opel company in my country, or what was the Opel company (because they close down now tsk tsk ) and they took the i think it was the license plate number and/or the chassis number and they went through their records and found it for me...so i just had to go through the long process of entering the code because i made 3 unsuccessful attemps. the more times you get it wrong the longer it takes to enter the code. but i got through now...i have my music for the long boring road!
Username: Gragra
Vilnius
Lithuania
Hi,
I need code for my radio Philips Car 400 2F3 from Opel Zafira.
No.: 93172248
Philips
330886636
GM040023203147
Thanks
Username: Gragra
Vilnius
Lithuania
my e-mail grifass@yahoo.com
Username: Posix99
I need code for RDS 22rc200/65
Prod no. FD0900499254563
S/N: PHAPKFY9254563
my email: posix99@hotmail.com
Thanks!
Username: Posix99
Nevermind, i have discovered it by myself.
Username: Gragra
Vilnius
Lithuania
The how of it, posix99?
Username: Ustaad_hc
Post Number: 628
Username: Lynx222
I de code radios philips grundig and other for 5euro (payment via paypall)
contakt lynx222@o2.pl
Username: Posix99
I have thoroughly searched the car manual, and found the code scribbelled on the corner of the last page.
Lucky me...
Username: Gragra
Vilnius
Lithuania
posix99 - roger.
Username: Slooow_jo
Help code needed for phillips 400 SN GM0400W1924003
My E-Mail Slooow_Jo@hotmail.co.uk
Username: Carlossecchi
Hi,
I am looking for a code for my Philips radio - 22RC200/65.
Product number: FD1103109405810.
S/N: PHAPKF39405810
Any help would be really great.
carlossecchi@gmail.com
Regards,
Tony
Username: Where_me_tea
hi can you please supply me with the radio code out of my pug 406 model number 22 dc 722/65
prod number fd 0497449074919
Username: Boglin
Please has anyone got a code for a renault phillips radio. Serial No. RN449FV4064632 it a model No. 22DC449/62L
Thanx.
Username: Iconeyk
As somebody i spend problem with my battery and now i also need of code for my Philips 22DC722/65 case Number PHAPCFV9074702 , prod N FD0497499074702 .
Please,would you find for my Philips the proper code,thks
Username: Panbg
I need car caode for Philips Car 400
Opel Vectra
1614438
GM 90 506 173 PA6-GF15
Username: Mys
I need code for my Philips Car 400
GM0400W2122868
ewa889@interia.pl
Thanks!
Username: Gsmmania
Hello,
I need the unlock code for PHILIPS CAR 400. The serial number is GM040013119629
pozriemsita@gmail.com
Thanks
Username: Anarrasulov
Plase, help me. Philips CAR 400
serial: GM0400X2273800
No: 90532621
CAR 400 2F3
Barcodes: 90222139675204 and 00399102273800
e-mail: anar@nakhchivan.az
Username: Jytäkkä
Hi all
I need a radio code for my Philips car 400 out of a Opel Astra 98
GM0400w1875904
NO 90541349
Type car 400
2F3
jussituning@suomi24.fi
Username: Killerno
Hi Guys,
please somebody help me.I couldn't find any code for my philips radio.
I need a code for this:
Philips 22DC593/62L
9022 215 93624
Prod number: FD0597214161510
S/N: RN593FV4161510
Thank you very much!!!!
E-mail: hyper83@gmail.com
Username: Mjssaqni
Philips
No. 90 462 560.
Type; car 400.
2F3.
Ministero P.T.
61/01175/22293/A.
DM 25-6-1985.
DM 27-8-1987
9022 213 96759 03.
003 9625 120055
Serial No. GM0400T1290055
Username: Mjssaqni
Philips No. 90 462 560.
Type; car 400.
2F3.
Ministero P.T.
61/01175/22293/A.
DM 25-6-1985.
DM 27-8-1987
9022 213 96759 03.
003 9625 120055
Username: Mjssaqni
Type; car 400.
2F3.
Ministero P.T.
61/01175/22293/A.
DM 25-6-1985.
DM 27-8-1987
9022 213 96759 03.
003 9625 120055
Username: Mjssaqni
Hi
Please can somebody help me with the code of my Opel car radio. Please find the particulars below.
Type; car 400.
2F3.
Ministero P.T.
61/01175/22293/A.
DM 25-6-1985.
DM 27-8-1987
9022 213 96759 03.
003 9625 120055
Muhammadsani453@yahoo.com
Username: Mjssaqni
Hi
Type; car 400.
2F3.
Ministero P.T.
61/01175/22293/A.
DM 25-6-1985.
DM 27-8-1987
9022 213 96759 03.
003 9625 120055
My E-mail is;Muhammadsani453@yahoo.com
Username: Bmilev
Grateful for any help I have just bought an Vectra with a Phillips CAR 400 S/N GM0400W2190628 and no code
Thanks in advance
My E-mail is : bobi_milev@yahoo.com
Username: Y12887
Hi Guys,
Philips car 400
GM040012978285
E-mail: y12887@hotmail.com
Username: Andyturley
Hi
I also need a code for a phillips car 400
gm0040023172806
my reg fj52svr
chasis no wolotgf3528056676
Thanks for your help
aturley3@csc.com
Username: Kaszym
Hi
I have problem with code radio for opel.
philips car400
GM0400W1934633
NO: 90 532 621
2F3
if it possible,
please generate code.
E-mail: demo2@poczta.onet.pl
PS: Tanks for advance
Username: Hfonseca
Hi ,
PHILIPS car 400
GM0400y2818450
N.º 09136106
2F3
1st code Bar 90222139975900
2nd Code Bar 00300222188450
E-mail: fonsecahugo@hotmail.com}
Thanks in advance
Username: Timpaxx
I need also a code for
Philips car 400
GM0400t1157504
no. 90 512 304
9022 213 96789 02
003 9603 1157504
timpaxx@gmail.com
thanks in advace
-T
Username: Jytäkkä
Hi all
GM0400w1875904
NO 90541349
Type car 400
2F3
Username: Lov1d1u
I need a code for Philips Car 400
gm0400w2004654
thanx
email : nicubt@yahoo.com
Username: Pettrovi4
please help get code
philips 22rc200/65
TOU758
prod no:FD0900479245981
PHAPKFY9245981
REF.PEUGEOT:
96 392 193 8001
PHK9245981
Username: Pettrovi4
email: pettrovi4@gmail.com
Username: Mdbnr
Please help me with my radio:
Philips Car 400
no.: 24 423 502
type: CAR2004 (E)
serialnr. GM020421284215
barcode1: 9022 214 04751 08
barcode2: 003 0246 1284215
email: 2nath4u@gmail.com
Many thanks in advance
Username: Minioworning
Hi i need code for
Philips car 400
no: 24455379
TYPE: car 400
s.n GM040013156615
barcode1: 90222139975402
barcode2: 00301483156615
my email: minioworning@wp.pl
Username: Parahulev
Hi i need code for
Philips car 400
no: 93172248
TYPE: car 400
s.n GM040023202934
barcode1: 9022 213 99784 02
barcode2: 003 0204 3202934
mail: parahulev@gmail.com
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Cassette > Need a code for Cass Philips Car 400 [ « Previous ] [ Next » ]
