Home > Message Board > Home Audio > Tuners > Poor Radio Signal
Author Thread: Poor Radio Signal
Eric Brosius
I receive poor radio signal (FM and AM) on my shelf system. I only get a handful of FM stations and no AM stations. The antenna that came with the unit doesn't help. A friend mentioned that you can some how hook TV cable into a stereo to boost signal.
Any suggestions??
Thanks,
Eric
Relevant Product Info
J. Vigne
Are you trying to hook up cable TV feed or the cable from your TV antenna? What type of connectors are on the back of your system to accept an external antenna?
Username: L20109
Use an external antenna. If the signal is weak, a booster will often solve the problem.
See:
http://www.bbc.co.uk/reception/factsheets/docs/fm_aerials.pdf
http://www.bbc.co.uk/reception/factsheets/docs/fm_radio.pdf
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Tuners > Poor Radio Signal [ « Previous ] [ Next » ]
