Home > Message Board > Home Audio > Subwoofers > Archive through May 10, 2005 > Where can i find a 15 inch subwoofer ...
Author Thread: Where can i find a 15 inch subwoofer box?
Username: Camaro_rs_7669
Ft lauderdale, Florida
Us
Where can I find a custom box for my 1992 Camaro RS that fit 2 15 inch subwoofers? If u have any clue on where to get the box please let me know.
Username: Ugzz
Pittsburgh, PA
Post Number: 8
my friend has a 90 camaro and he couldnt find one, he build one from wood, looked ugly but he was real careful with the seals and it was tight and sounded great... his had 2 15s and a 10.. no one believed he could fit it in the camaro, but he managed.. barely hehe good luck though
White 91 Camaro RS
I own a 91 Rally Sport. I had to build my own custom enclosure in the hatch area. Here are some sites on building your own box.
http://www.crutchfieldadvisor.com/reviews/20030701/build_box.html
and
http://www.carstereo.com/help/Articles.cfm
I doubt you'll find an enclosure for a 15" sub so I would just build one. After I built mine people would ask to hear and see my system. After they would see my enclosure they would want one and ask where to get it. Yeah I ended up making a healthy profit in my spare time doing something I love, building sub enclosures.
White 91 Camaro RS
Oh yeah It doesn't cost much to build a sub enclosure either. Depending on the tools you have access to. Like table saw or even a jig saw or a circular saw. You basically will need MDF (Material Density Fiberboard) sometimes sold as novoply, wood screws, wood glue, caulking, carpet, and spray adhesive to attach carpet.
My next project is learning how to fiberglass and enclosure.
90 red rs camaro
i had the same problem. i have a 90 rs and i went to about every audio store within 25 miles of me and every oneone of them told me that i couldnt fit 2 15"s but i ended up buyin them anyway. i made my own box for them and it sounds off the hook. it didnt cost much either because i had all the tools to do it.
Username: Audiobahnmahn
Yo, if you looking for a box for a 15 inch sub check oiut cardomain.com you can specify your vehicle before your order...see ya.
Yo, if you looking for a box for a 15 inch sub check out cardomain.com you can specify your vehicle before your order...see ya.
Username: Fareastkid
Fukushima, N/a
Japan
I have a 1999 honda oddyssey and I plan on putting 2 SPLW-15's inside it.. what would be a good box for this minivan? if you have pic please mail them so I can get some kind of Idea what it would look like. now I only have a banpass box and I don't think the mearsurements are correct for that subwoofer! help please.
tia
Fareastkid
If anyone knows where I can get plans to build a box for a 1991 Camaro RS please email me and let me know. Thanx.
does any one know of where to get plans to build a box for 2 15" subs. space isn't a problem cuz i have a 1992 ford explorer. looking for good plans to build a box that can handle these subs. thanks for any help.
schrades
does any one have pics for custom build box for 94-97 honda accord
Username: Subfanatic
Walton, Ky
Post Number: 3068
andrew, im a custom wood worker, box builder, if u give me dimensions ill build you one for your camaro, email me at. bebuzzin11@hotmail.com
Home > Message Board > Home Audio > Subwoofers > Archive through May 10, 2005 > Where can i find a 15 inch subwoofer ... [ « Previous ] [ Next » ]
