Thread: Missing channel on old Technics SL-D303 |
Wayne Steinhour Unregistered guest |
| Posted on Friday, November 05, 2004 - 09:37 am: |
I recently picked up a nice old SL-D303 along with some other stereo equipment at an auction. One channel on the turntable does not work at all. (If the ground is diconnected, this channel puts out a loud humm, but this goes away when it is grounded.) Is this likely to be a cartridge problem or is there some other explanation? Thanks in advance for help on this. |
| Posted on Sunday, November 07, 2004 - 11:41 pm: |
If your cartridge is removable ,remove it and clean the 4 contacts on the back with contact cleaner or pure alcohol,i had similar problem with an other Techcnics model. |
| Posted on Monday, December 13, 2004 - 08:50 pm: |
I am having the exact same problem with an SL-D303 I was recently given. I only had sound on the left channel. I ordered a new stylus, and a new cartridge, and neither solved the problem. I just cleaned all the contacts with rubbing alcohol. Still no luck. But I notice that the wires connecting the headshell to the cartridge are loose. After changing cartridges a couple times, and disconnecting and reconnecting the wires, I found that I was getting sound on the right channel, and not the left. I think the headshell wires must be the problem, in my case. I am ordering a new headshell. I am a turntable novice, but it seems to me like very bad engineering to have a $10 part be such a weak link. And it sucks to discover this after spending $150 unnecessarilty. (But I guess in this day and age, being a vinyl enthusiast is not about logic or practicality...) |
| Posted on Thursday, December 16, 2004 - 12:03 am: |
Further update: It wasn't the headshell either! It was the amplifier. Now I need to find a new amp with a phono input. |
