Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through February 12, 2004 > Using 4 ohm speakers with 8 ohm amp
Author Thread: Using 4 ohm speakers with 8 ohm amp
This may sound stupid but can i use my jbl control 1s rated 4 ohms as surrounds on an amp rated 6 or 8 ohms.
Username: Project6
Post Number: 134
that is not a stupid question at all, it is better that you know and not guess and hope for the best, right?
anyway, there are very few amps that can handle a 4 ohm load without heating or working a little too hard and clipping or go into protect mode.
you may want to steer clear of that unless your amp can handle it.
cheers
Jb1677
How can you say there are "few amps" that can handle a 4 ohm load? There are and have been for many years a WIDE selection of amps that can handle 4ohm loads.... are you sure you did not mean not many receivers ?
J
Username: Project6
Post Number: 140
absolutely correct. However, I was referring to amps that are only specifically rated at 6 to 8 ohms.
cheers
Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through February 12, 2004 > Using 4 ohm speakers with 8 ohm amp [ « Previous ] [ Next » ]
