Home > Message Board > Home Audio > DVD-Audio & SACD > Dvd durabrand dur-1700 for multizone.
Author Thread: Dvd durabrand dur-1700 for multizone.
can anyone know how to make it work on multizone
for dvd durabrand model dur-1700 ?
Relevant Product Info
did you find it? if yes, please let me know... :-)
lobo
The code is 251535. For "how to" see "Initial IDM-1731"
have fun
lobo
sure lobo ?
Username: Rlozano
Hidalgo, Tx
I have a MAGNAVOX MDV110 and it's region 1.
I need the code for region free, please.
Thanks!!!
This works?!?!
I wanna know...because I'm from Brazil and I wan't to buy a Dur-1700...
This works?!?!
I wanna know because I'm from brazil and I wanna buy a dur-1700 from Walmart...but first..."this works in my region?" you know...
lobo999
I can confirm that unlocking my Durabrand Dur 1700 worked using code 251535. Bought the unit in October at a Walmart in Kansas.
Username: Jacktorrance
Hello. I'd like to see if the "251535" code for the Durabrand DUR-1700 portable DVD player works.
How do I get into the setup screen in order to enter the code "251535"? I did a search on the "Initial IDM-1731" in order to read how to do it and did not find anything.
Thank you,
JT
cnstarz
I cannot get my DUR-1700 to play on other TV's. I know to change the switch from "tft" to "video out" but it just scrolls rapidly and in black and white on a TV. Can anyone help? Otherwhise, I love this little player.
Username: Quistormom
I need to find a new car adaptor for the DUR-1700 Durabrand DVD Player - does anyone know where I can get one?
Everyone is talking about what they need to go with this product but, not one person has said that is is a good product to purchase. Can you please tell me if I will be wasting my money on it.
necesito saber como convertir mi dvd durabrand modelo 2005, zona 4 en multizona
Please, I have a durabrand DVD 2005 model and I would like to open it for all zones. Does anyone could help me?
Thank you!!
Username: Animusfree
Durabrand Dvd-2005
Turn the DVD on
Open the lid
Press 'Stop' on the remote
Then 734466
You will now be in the setup menu.
Use the right arrow to open the Region Options and select '0' for region free.
Username: Cannavaro
Hi everyone i have seen the post which tells you how to unlock a Durabrand 2005 and i have tried it but it's not working......any tips??
Username: Nicky1983
HELP ME!!!!
I own a duraband 2005 dvd player and i dont know if it is region free or ho to make it region free. I tried the tips above but they dont seem to work, please help.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > DVD-Audio & SACD > Dvd durabrand dur-1700 for multizone. [ « Previous ] [ Next » ]
