Thread: RCA CDRW121 Problems...HELP!! |
New member Username: Wishpony
Post Number: 1 Registered: Oct-04
| Posted on Saturday, October 30, 2004 - 10:07 pm: |
I keep trying to put disks in on the B (record side) and it keeps saying no disks...whether blank cdrs, bought cds, a cd cleaner. I can't get an email to RCA to ask them and I don't know what to do. THe manual doesn't give any kind of troubleshooting for it. I have turned the unit off completely for the time being. Any help I can get would be appreciated. |
Relevant Product Info
wiredworld Unregistered guest |
| Posted on Wednesday, November 24, 2004 - 08:38 am: |
Make sure disk says "Audio CD Recordable". I ran into this problem when I first tried to burn a cd. It's on page 16 of the manual. |
Post Number: 3 Registered: Oct-04
| Posted on Wednesday, November 24, 2004 - 09:03 am: |
Yep, know that. I also put music cds I've bought from the music stores and it doesn't read those either. It just comes up no disk. |
| Posted on Thursday, November 25, 2004 - 06:52 pm: |
Try Maxell, TDK, or Fuji Music cd disks |
Post Number: 4 Registered: Oct-04
| Posted on Thursday, November 25, 2004 - 08:17 pm: |
I am using the came cdrs that I have recorded on for over 100 times. And again I have put store bought prerecorded music cds and they will not read either. They all come up NO DISK after attempting to read them. |
New member Username: Cryztal6
Post Number: 1 Registered: Jan-05
| Posted on Tuesday, January 25, 2005 - 11:09 am: |
Hi, I am having the same problem "I keep trying to put disks in on the B (record side) and it keeps saying no disks". Have any of you found a solution? Thanks. Crystal |
| Posted on Friday, May 13, 2005 - 08:20 am: |
My RCA CDRW121 unit reads "Digital Audio Disc Only" on the B side when I try to record. I tried CDR's and CDRW's, but its not reading either. Any thoughts? |
| Posted on Wednesday, July 27, 2005 - 07:16 pm: |
The only cd I found to work in this player is Sony CD-R MUSIC for digital quality sound. |
| Posted on Sunday, October 16, 2005 - 06:27 pm: |
I just got a CDRW 121 used and ran into this, but got some Memorex Music CDR's and they are recording. |
New member Username: Princesa
Post Number: 1 Registered: Jan-06
| Posted on Tuesday, January 03, 2006 - 09:14 am: |
Can someone tell me where I can locate the instruction manual for the RCA CDRW121? |
New member Username: Simctd
Post Number: 1 Registered: Feb-06
| Posted on Saturday, February 11, 2006 - 07:38 pm: |
You can get instruction manuals at http://www.thomsonnetwork.com. You can download them in PDf form. I am having similar problems with my RCA CDRW120. It tell me blank cdrws are unreadable. |
| Posted on Tuesday, February 28, 2006 - 04:30 pm: |
Need to know where I can get part # 257938 - Mechanism Recorder CD/W Driver this is for a CDRW120 (RCA) |
New member Username: Luisito424
Post Number: 1 Registered: Jun-06
| Posted on Thursday, June 01, 2006 - 10:03 pm: |
Please, I have a RCA cdrw120 recorder 2 years ago, and then, today, I got troubles with it because I couldn't to burn a cdr audio, the same ones that I always burn. The message is: no audio cd... what can I do? wow!, I don't want to think that I have to buy another one again.. do you think that trouble is repairly?.......please,answer me... thanks, Luis Font |
Post Number: 2 Registered: Feb-06
| Posted on Friday, June 02, 2006 - 04:52 pm: |
Luis This info I found at the RCA web site. Check it out and see if you can find any answers there or the phone number for RCA or Thomsen. It may be as simple as using using different cdr's. Good luck. Dear Customer: Thank you for your comments about the www.rca.com website. Currently, owner's manuals may be viewed on the site by using the search field function at the top left corner. Please put your model number in the search field. You can also view a digital owner's manual on the web site, http://www.thomsonnetwork.com. Click on Instruction Books. Follow the directions on how to do a Search for your product. After finding your manual, please click on the link. Your instruction book should display in your browser. If you do not see anything, you will need a pdf reader to view this document. You can get the free download at http://www.adobe.com/products/acrobat/readstep2.html. If you would like to purchase an owner's manual: Please go to the web site, http://www.thomsonnetwork.com. Click on Publications Ordering. Click on Instruction Book Search. Follow the directions on how to do a Search for your product. After finding your manual, please put a Quantity in the box and click ADD. Then click View Order. Fill in all the proper information. Unfortunately, we do not have every instruction book for every product. If your product is older than 1993, there is a good chance that your instruction manual is currently not available. We appreciate your interest and thank you for contacting us. [Q103185606302394] Sincerely, Chad 0602081837 This response is being provided by Thomson Inc., the manufacturer of RCA consumer electronics products |
New member Username: Sylviaddddd
Miami,
Florida
United State
Post Number: 1 Registered: Aug-06
| Posted on Tuesday, August 01, 2006 - 12:25 am: |
Hi.I need a instructions manual and a remote control for a CDRW 121 RCA. Thanks for you help. ZACARIAS GUMBS |
New member Username: Dubb_o_b
Post Number: 1 Registered: Jan-07
| Posted on Wednesday, January 17, 2007 - 07:09 pm: |
Does anyone know where I can purchase a fully operational RCA CDRW 121 player/recorder. Does anyone know where I can purchase a new RCA cd mechanism part# 268558? I am not able to record externally or disc to disc with my own CDRW 121. It's about 7 years old, but I love it. RCA has said that the recorder and parts for the recorder are no longer available. |
Post Number: 2 Registered: Jan-07
| Posted on Wednesday, January 17, 2007 - 07:40 pm: |
I am a band member and at all our practice's I record the band live with my RCA CDRW 121. I know I should be updating with new technological advances but I can't find any other CD recorders that offer the (2) mic inputs, each a separate channel. This unit is some of the 1st stand alone analog recorders that hit the market around 2000-2001. I've never seen (2) mic inputs offered by any other company. I too have experienced a few minor disc reading problems but once you find a disc that works well stick with it and excerise patience. Is everyone out there burning cd's on a computer? I hope not because that will signal the end to the beloved stand alone analog recorders.If you look at the affordable recorders on the market now, they don't even have (1) mic input! I have been told by several sales people that SONY RCD-W500C is about the only recorder still on the market, and that they are considering phasing it out because of the high use of recording via computers. I am sad to hear that. Once again for all you readers and posters that are not happy with your RCA CDRW 121 if you want to sell it I'm interested. I would buy a newer model by almost any name brand if I could locate one with (2) separate mic inputs each a separate channel. I don't see them available. If anyone knows of something please respond. |
San Juan,
Puerto Rico
Puerto Rico
Post Number: 2 Registered: Jun-06
| Posted on Thursday, January 18, 2007 - 02:58 pm: |
Hi Robert, thanks for writing, I received your message yesterday. I showed my RCA CDRW 120 Recorder to a technician and he told me that it's very complicated to fix the problem because it's more expensive than to buy another one. I took my equipment and since then I use it for playing cds only. I understand that you want to record the music of your band analogically, I think it's a good option. Do you want I sell my RCA CDRW 120 Recorder to do it a reparation?, remember that my equipment has troubleshooting in the recording. Where do you live?. I live in Puerto Rico and I don't know how much is the shipping. What is the name of your band?.. Ok, I am fit to sell the equipment but you had to know about it. Luis Font |
