Thread: Speaker static problem |
New member Username: Trenneck
New Albany,
OH
United States
Post Number: 1 Registered: Oct-04
| Posted on Tuesday, October 26, 2004 - 01:27 pm: |
I have a Sony STR DB930 A/V Receiver with brand new Polk tower speakers, and a polk center speaker. I notice a bit of static coming from all speakers at low levels (I believe it is always there, just more noticable at low levels)from any/all sources. I replaced my Boston Acoustic's as I believed it was a speaker problem which it is obviously not. I am thinking it must be the receiver but hate to buy a new one. Any advice? |
Relevant Product Info
Silver Member Username: Rh1
Post Number: 358 Registered: Jun-04
| Posted on Tuesday, October 26, 2004 - 01:33 pm: |
Re-check your connections, also make sure your wires are isolated power verse speaker wires. That might be the culprit. Did you have this receiver hooked up before to different speakers? |
Post Number: 359 Registered: Jun-04
| Posted on Tuesday, October 26, 2004 - 01:34 pm: |
sorry, after reading my post it may seem confusing. Make sure your power chords are not crossing your speaker wires |
New Albany,
OH
United States
Post Number: 2 Registered: Oct-04
| Posted on Tuesday, October 26, 2004 - 01:43 pm: |
The left/right wires are crossing power cords, but the center is not and all 3 have static. Yes this receiver was hooked up to a set of Boston Acoustics that had the same problem. |
Post Number: 360 Registered: Jun-04
| Posted on Tuesday, October 26, 2004 - 02:10 pm: |
The only other thing I could point towards would be line conditioning. Do you have "snow" on the tv or static when, say you turn on a blender or something? |
