Thread: How can I connect my Xbox to my Logitech Z-640 5.1 Surround Sound? |
New member Username: Praisemacs
Post Number: 1 Registered: Oct-04
| Posted on Saturday, October 23, 2004 - 10:45 pm: |
I recently obtained a Logitech Z-640 Dolby Digital 5.1 Surround Sound System and quickly set out to connect it to my Xbox (I do have the Advanced AV pack). The problem comes with the fact that the only way that the Logitech Z-640 can recieve true Dolby 5.1 Surround Sound is through 3, 3.5mm jacks(the kind used on computer sound cards and headphones), and the Xbox uses an optical connection. How can I convert the optical signal into 3, 3.5mm mini-phone jacks for use with my speakers? |
Relevant Product Info
Post Number: 2 Registered: Oct-04
| Posted on Sunday, October 24, 2004 - 01:41 pm: |
If it helps here is a URL to a picture of the Jacks that my speakers use to recieve sound. http://img.photobucket.com/albums/v290/praisemacs/Micro-plugs.jpg |
New member Username: Release
Post Number: 6 Registered: Oct-04
| Posted on Monday, October 25, 2004 - 09:37 am: |
Are you sure that Xbox uses an optical connection? As far as I know that product it doesn't. |
Post Number: 3 Registered: Oct-04
| Posted on Monday, October 25, 2004 - 11:44 am: |
The Advanced AV pack accessory has an optical audio out. |
New member Username: Daves666
Post Number: 10 Registered: Oct-04
| Posted on Monday, October 25, 2004 - 01:11 pm: |
Not sure if this will help but: I just hooked my Xbox up to a set of Altec Lansing MX 5021s [2.1 system] and it worked without a hitch. The ALs came with a Y cable that had a 3.5 mm jack on one end and 2 RCA inputs on the other. Good luck |
Post Number: 4 Registered: Oct-04
| Posted on Wednesday, October 27, 2004 - 11:30 pm: |
Wow... I feel like a twit... the reason that it doesnt accept digital optical of digital coaxial is because the speakers are freakin ANALOG. They simply didnt have a digital decoder. I returned them and am now ordering Logitech Z680s which come with a reciever. |
