Home > Message Board > Home Audio > Amps > Archive through October 30, 2004 > Tube Amp & NAD C352
Author Thread: Tube Amp & NAD C352
Username: Tzeleung
Hi! I'm going to buy my first serious Hi-Fi system, I'm very exciting and nervous and I need you guys' opinion
I read a lot of review about Amp. It seems that a lot of people still love Tube Amp, and think that for a $500-600, the sound of Tube Amp is better. But then I saw NAD C352 always show in the review.
So here are my questions:
1) If I can only spend $1,000-1,200 USD to buy a amp plus a pair of speakers, should I go for Tube or integrated amp?
2) What is the best combination of Tube Amp + speakers based on my budget?
3) What is the best combination of integrated Amp + speakers based on my budget?
4) I'm thinking of NAD C352 + B&W DM602 S3, is there any combination do better than this?
I listen wide range of music such as rock to jazz, new age, clasic, techno...
Thanks you very much for your help.
August
Which tube amps in the price range $500-600 are you considering? I thought a descent tube amp costed more than that.
Username: Tzeleung
I'm thinking of CONRAD JOHNSON MV50 Tube Amp or Norh SE 9, do you have any suggest if I can go a bit more than $600?
Username: Jonmoon
Post Number: 115
There is support at this forum for JoLida Tube Amps:
http://db.audioasylum.com/cgi/search.mpl?forum=amp&searchtext=JoLida
Also see:
http://audioreview.com/Amplifiers/Jolida/PRD_115848_1583crx.aspx
Home > Message Board > Home Audio > Amps > Archive through October 30, 2004 > Tube Amp & NAD C352 [ « Previous ] [ Next » ]
