Home > Message Board > Home Audio > Integrated Amps > Archive through November 19, 2004 > Arcam Diva CD73T with Rotel RA-1062 o...
Author Thread: Arcam Diva CD73T with Rotel RA-1062 opinions?
Username: Number9
Hello, Is anyone using this combo/any opinions? Thank you, Michael
Sjarelke
Not that exact combo, but i bought the Divd CD73T with the arcam 65+ receiver. I also tested the arcam a80, which admittedly sounded better but was over my budget. It is about the same price as the rotel 1062 tough, so you could seriously consider it (at least try it)
Jesse
Username: Number9
How come I can't find the reply to my post by "Sjarelke"???
sjarelke
What do you mean - you can't find the reply?
Home > Message Board > Home Audio > Integrated Amps > Archive through November 19, 2004 > Arcam Diva CD73T with Rotel RA-1062 o... [ « Previous ] [ Next » ]
