Thread: Goddamn Aiwa |
New member Username: Japput
Dublin Ireland
Post Number: 1 Registered: Oct-04
| Posted on Friday, October 22, 2004 - 06:25 am: |
I purchased an AIWA NET-MD. Got SonicStage 2 with it.No matter what I do, SonicStage gives an error on reading the goddamn CD. Falls over. Tried re-installing many times. No good. In desperation, I got Realplayer (V10 Free), and that doesn't recognise my MD! Got different device drivers (tried the Realplayer Sony device driver) no good. Hit transfer and after 50% transferred-falls over. Is this as good as it gets? Any ideas? |
Dublin Ireland
Post Number: 2 Registered: Oct-04
| Posted on Friday, October 22, 2004 - 06:35 am: |
Should have mentioned I'm on Windows XP.. |
Dublin Ireland
Post Number: 3 Registered: Oct-04
| Posted on Friday, October 22, 2004 - 02:18 pm: |
Problem solved! The Hotfix for Windows XP has a negative impact on SonicStage.It's patch KB840987 to be exact. Go into Add/Remove programs and remove this patch and all was fine for me. Note Windows XP will try to download this everytime again so you will have keep removing it until a permanent fix is found. I saw this in some other post. Thanks. |
Unregistered guest |
| Posted on Friday, December 03, 2004 - 03:31 pm: |
i did it, but i still can't transfer my mp3 files to my minidisc. "Cannot convert the specified song. SonicStage doesn't support the file format of the song." |
| Posted on Sunday, February 13, 2005 - 05:14 pm: |
i'm so stuck i have a t.v with a video attached to it and i have put a paasscode on it and i have forgotten it... there is a possible 9999 that can be put in but are there any other ways in which to find the passcode out ?? i need help |
