Thread: Doubt about interconnection |
Bronze Member Username: Argento
Post Number: 68 Registered: Apr-04
| Posted on Wednesday, October 20, 2004 - 10:09 am: |
I have a doubt about an equipment interconnection. If I want to connect a receiver with pre-outs to an integrated amp or a pre/amp, How should I do the connections between then? Thanks for the help.
Post Number: 70 Registered: Apr-04
| Posted on Wednesday, October 20, 2004 - 10:26 pm: |
I want to use the equipment for music (the integrated or the pre/amp) and for movies (the receiver) without change connections and using a single pair of main speakers. Which is the right configuration?
Post Number: 1726 Registered: Dec-03
| Posted on Thursday, October 21, 2004 - 06:21 am: |
You want to use a single pair of speakers with 2 amplifiers??? You still need a switch to go back and forth between the amplifiers/receivers/integrated amps. |
Post Number: 71 Registered: Apr-04
| Posted on Thursday, October 21, 2004 - 11:04 am: |
Berny says: You want to use a single pair of speakers with 2 amplifiers??? Yes, that's the idea. Would I connect the mains pre-outs of the receiver to an AUX input of the integrated or pre?
Post Number: 72 Registered: Apr-04
| Posted on Thursday, October 21, 2004 - 11:06 am: |
Of course, the mains speakers should be connected to the integrated or amp. |
