Thread: Best bookshelf monitor for under $1500? |
balthus Unregistered guest |
| Posted on Monday, October 18, 2004 - 01:15 am: |
Hey folks, These are my contenders so far: spendor s3/5 se monitor audio gr10 north acoustics spirit totem rainmaker Anything else I should consider? This is for a small room (12' x 11') and would be paired with a small subwoofer. |
Relevant Product Info
Silver Member Username: Landroval
Post Number: 838 Registered: Feb-04
| Posted on Monday, October 18, 2004 - 04:10 am: |
I think the GR10 lost in comparison to the half-the-price Quad 12L, give it a listen, it's good. Dynaudio Audience 52SE is very nice and B&W 705 isn't bad either. |
Silver Member Username: Rh1
Post Number: 282 Registered: Jun-04
| Posted on Monday, October 18, 2004 - 10:45 am: |
check out What Hi-Fi magazine (November issue), they have a buyer's guide in this issue. this should help a bit in your decision |
CarSubWoofer Unregistered guest |
| Posted on Monday, October 18, 2004 - 11:28 am: |
another vote for Dynaudio Audience 52SE, or the Axiom M22ti. |
OnimushaLord Unregistered guest |
| Posted on Monday, October 18, 2004 - 12:58 pm: |
In no particular order: Reference 3A De Capo i ATC SCM12 Quad 12L Dynaudio 52 SE Spendor S3/5 SE Dynaudio BM6A (active monitors) Wilson Benesch Arc Onix Reference 1 AVI Neutron IV AVI Pro Nine plus Pro Ac Reference Signature 8 Veracity HT1 (Salk Sound) Cheaper but offering competitive admirable performance would be: Quad 11L Epos M5 MA B2 MA S1/S2 Aegis Evo One Axiom M22Ti KEF Q1 Klipsch RB-35(a tad bright) ATC SCM7 Cheers! |
J. Vigne Unregistered guest |
| Posted on Monday, October 18, 2004 - 01:16 pm: |
Well now, after all those suggestions we still have no idea what "sound" you are looking for; or, what the rest of the system is or will be, including the room. Some idea of musical tastes would be helpful while you're at it.
| Posted on Monday, October 18, 2004 - 01:29 pm: |
Thanks for all the suggestions. With regard to J. Vigne's comments...musical tastes are eclectic: jazz, rock, classical, latin...I listen to it all. As I said, the room is small (12' x 11') and there is no room for stands, so the speakers would actually be on a bookshelf. Amp is the integrated Rotel 1062 with a Rotel RCD-1072 cd player. Also looking for a small sub for extending the lows. I prefer accurate sound with minimal coloration. |
| Posted on Monday, October 18, 2004 - 01:38 pm: |
If you want new speakers I would go with the Spendors. There are lots of good bargains to be had in pre owned products. Read this thread with particular attention to Ghia's post: http://forum.ecoustics.com/bbs/messages/1/104962.html
