Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through October 25, 2004 > Best match for Polk
Author Thread: Best match for Polk
Username: Daslolo
Los Angeles, CA
United States
Hi all,
I received a 5.1 set of Polk speakers. When I connected them to my 5760 I decided I now needed a good receiver.
So what's the best match for Polk speakers? I'd like to stay under $800 as I already burned $1500 in speakers.
Cheers.
Username: Elitefan1
Post Number: 724
Marantz 5400, Elite vsx52,H/K 330 would all be good match's with your Polk's as would any other model in those lines you can afford. What Polk models do you have ?
Username: Bleustar
Pensacola, Florida
Post Number: 157
The HK AVR430/435 or AVR630/635 would be better than the AVR330. Marantz Sr5400/SR6400 or NAD T753 I if your willing to search around I think all can be purchased for under $800.
Username: Daslolo
Los Angeles, CA
United States
Thanks for the feedback. I read that NAD has humming problems so I'll probably go for Marantz or HK then.
I have the rti4 back, rti6 front and 8 center with a 550 sub.
I read that polk are very neutral, is that the case with the rti?
Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through October 25, 2004 > Best match for Polk [ « Previous ] [ Next » ]
