Home > Message Board > Home Audio > Amps > Archive through October 30, 2004 > Carver C5 remote?
Author Thread: Carver C5 remote?
Username: Fastback4
California, Ky
Usa
Thanks for the quick response to my first question...My carver C5 remote appears to be able to operate a tuner as well as a cd player as there are commands on the remote...Would a tuner and cd player have to be a Carver brand to function via my preamp remote? Also, there is a 1/8 jack at the back of my preamp that reads external remote sensor. What is this jack for?...Regards....Tom
J. Vigne
I'm not that familiar with the remote for a C-5 but if there is a button on it that is marked "set", "address" or something similar that would put it in a lerning mode then it probably can learn codes. Otherwise it is meant for Carver eqipment only. The remote sensor jack is used to trigger the on off functions of accessories. I wouldn't be concerned about it as it's function doesn't relate to the performance of the equipment.
Home > Message Board > Home Audio > Amps > Archive through October 30, 2004 > Carver C5 remote? [ « Previous ] [ Next » ]
