Home > Message Board > Home Audio > Amps > Archive through October 30, 2004 > Carver C5 remote?
Author Thread: Carver C5 remote?
Username: Fastback4
California, Ky
Usa
Thanks for the quick response to my first question...My Carver C5 preamp has a remote controll. It appears to be able to controll a tuner and a cd player. Would i be right to assume that it can do this if the tuner and cd player are Carver components? Also, there is a small 1/8 jack located at the rear of the preamp that says external remote sensor..What is that for...Regards to all......Tom
Home > Message Board > Home Audio > Amps > Archive through October 30, 2004 > Carver C5 remote? [ « Previous ] [ Next » ]
