Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through February 12, 2004 > Dipole speakers for surrounds?
Author Thread: Dipole speakers for surrounds?
Username: Ollieburger
What are the advantages/disadvantages of rear dipole surrounds. How critical is placement? I'm looking at teh KEF Q2DS. Any comments.
Thanks
KidA
I'm also looking at this. I just bought MA SFXs and I'm wondering for 5.1 if I should place them on side or back wall? and should I run them as bipole or dipole?
hudson
Kida, what did you buy the s10's or 8's for fronts... what did you get for you receiver?
I am looking at monitor and pairing it with either integra 8.4 or their new seperates.... if you look in the brochure they say the fx's should be side wall mounted as a dipole ... they don't mention settings for real wall mount other then they can accomodate both.
Personally, i'd call the guy you got them from as I'm sure he'll know.
KidA
hudson, thanks for the info. S8 and s10 were too tall for my placement on the edges of the fireplace.
My system:
H/K 7200
MA S6, SLCR, SFX
SV Sub 25-31Pci tuned to 22hz
Elitefan and Hawk have a lot of experience with the setup you are looking at. They were a great help to me.
Hudson
Sounds like a nice system. good work. I need to fill up space so no worries for me. I have read a number of very good write ups on the MA s6...
Enjoy...
KidA
FYI, soundcityoutlet.com has some good deals on open box monitor audio speakers. Including the S8s in black for $887.
Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through February 12, 2004 > Dipole speakers for surrounds? [ « Previous ] [ Next » ]
