Home > Message Board > Home Audio > Amps > Archive through October 30, 2004 > Marantz SR 5300 - ticking from Front...
Author Thread: Marantz SR 5300 - ticking from FrontRight channel.
Pedro
SO I just noticed something new today...
My Marantz SR 5300 has a very slight clicking in the right front channel.. I notice it while I move the volume through the -55db -38db range. There is an slightly audible "tick" for each DB change. Once the volume stops changing, so does the ticking.
A day ago, I installed 12 gauge speaker wires to Paradigm Monitor 7's in front. Perhaps this "DB volume ticking" was there all along, but I just noticed it after the better wire.
(This happens with either the remote or knob. I hear it only in the FRONT RIGHT channel but in no other channels. It happens with analog FM radio sources or digital DVD sourced material. )
Has anybody heard of this problem with a Marantz? If it indicates something that could get worse, or a bad manufacturing run, I suppose I should get it fixed under the 3 year warrantee. Should I be concerned? What do you think?
Overall, this receiver has been a very easy one to live with... The remote is kind of junky, and it could be punchier, but I love the clean sound, good for me now. But I'm bummed.
Much thanks,
Pedro
Home > Message Board > Home Audio > Amps > Archive through October 30, 2004 > Marantz SR 5300 - ticking from Front... [ « Previous ] [ Next » ]
