Thread: What Receiver Should I Buy? |
New member Username: Ruggyvernon
Denver,
CO
Post Number: 1 Registered: Oct-04
| Posted on Wednesday, October 13, 2004 - 04:53 pm: |
Okay, here’s the set-up: Speakers: Axiom M22ti fronts Axiom QS8 surrounds Velodyne DLS-4000 sub I’ll be doing 50% music and 50% movies. I’m looking in the $400-$500 range – what do you think of these options (or others?) Yamaha RX-V750 Denon AVR-2105/AVR-885S Harmon Kardon AVR 330 Marantz SR6400
Silver Member Username: Hawk
Highlands Ranch,
CO
Post Number: 645 Registered: Dec-03
| Posted on Thursday, October 14, 2004 - 12:40 pm: |
Mark: 1. Harman/Kardon AVR 330 2. Marantz SR6400 3. There is no 3--choose from above. Your Axioms are another case of a speaker that is soemwhat bright. This gives it some fine detail, but the wrong electronics will make the sound hard and edgy (i.e., Yamaha). Yamaha is bright as well, so it makes a poor combo, IMO with your Axioms. Similarly, the Denon is not bright, but had a very "dry" quality to the sound, which can make your axioms sound a bit gritty. Not good. Stick to the H/K or Marantz and enjoy! |
Silver Member Username: Landroval
Post Number: 823 Registered: Feb-04
| Posted on Thursday, October 14, 2004 - 12:56 pm: |
I would have to say Marantz first, H/K second. Marantz is cleaner and more detailed, while the H/K is somewhat muddy, but also has slightly annoying highs. If you dont agree I suggest you go and listen to the new H/K's. Although AVR430/630 are clearly better than the 1/2/330. |
Denver,
CO
Post Number: 2 Registered: Oct-04
| Posted on Thursday, October 14, 2004 - 02:50 pm: |
Thanks for the recommendations - I'm a newbie, so I'm still getting my hands around the "bright" and "warm" stuff. I heard the Marantz SR5400 at the store and it sounded great through some Acoustic Energy Reference series speakers - the salesman said the Marantz had great "software," too. |
Silver Member Username: Jonmoon
Post Number: 107 Registered: Dec-03
| Posted on Thursday, October 14, 2004 - 03:44 pm: |
Ruggy, have also heard that the new Marantz SR5500 might be worth waiting for. http://www.audioholics.com/forums/showthread.php?t=4323&highlight=marantz+sr5500 |
