Home > Message Board > Home Audio > Amps > Archive through October 30, 2004 > Pro DJ amplifier
Author Thread: Pro DJ amplifier
j-dub dub
hey has anyone ever used a dj amp? i noticed that they all have rca inputs, but they have "banana plug" outputs. does anyone know if you can just connect speaker wire straight into these outputs? or will i need some kind of converter? someone please help. thanks.
Username: Project6
Post Number: 1697
what have you tried to do?
What amp is it?
j-dub dub
i havent tried anything yet.
i was wondering if i can connect regular speaker wire from the "banana plug" output straight to the voice coils of my speakers. is this possible? or do i need some sort of convertor?
Username: Project6
Post Number: 1713
Banana plugs are just a convenience connector, specially if you are pulling them in and out of the amplifier constantly. You should be able to connect the speaker wires directly to them.
j-dub dub
thanks man i appreciate it
Home > Message Board > Home Audio > Amps > Archive through October 30, 2004 > Pro DJ amplifier [ « Previous ] [ Next » ]
