Thread: Maybe the wrong place but.... |
New member Username: Cmangle
Post Number: 2 Registered: Oct-04
| Posted on Tuesday, October 12, 2004 - 02:01 pm: |
A question about Sony SoundForge... I need to be able to adjust the EQ, WHILE the clip is playing. Under "Process" the EQ listed stops the clip from playing. Is there a real time way to adjust EQ? |
New member Username: Sungamer
New York,
NY
Post Number: 5 Registered: Nov-04
| Posted on Thursday, November 18, 2004 - 01:39 pm: |
Not in Soundforge. Use a mixer (digital or otherwise) |
Post Number: 3 Registered: Oct-04
| Posted on Thursday, November 18, 2004 - 07:03 pm: |
thanks Mei-Ying you're in NY I'm just outside of AC |
Post Number: 4 Registered: Oct-04
| Posted on Thursday, November 18, 2004 - 07:04 pm: |
sorry Mei-Ting |
New York,
NY
Post Number: 9 Registered: Nov-04
| Posted on Thursday, November 18, 2004 - 07:29 pm: |
Just had another thought on this - Depending on what you need to do, you might be able to use this. Start the eq, then do a realtime preview. Then you can adjust the EQ and listen to the changes. |
