Home > Message Board > Home Audio > Amps > Archive through October 30, 2004 > Amp for 100w RMS 11ohm siren speaker
Author Thread: Amp for 100w RMS 11ohm siren speaker
Username: Tyco
Fort Collins, Colorado
I am a firefighter and I have 2 speakers off one of our trucks, they are 100w RMS 11 ohm megaphone speakers. I need to find a amp that will power them. Any sugestions??
J. Vigne
What are you going to use them for? Audio?
Username: Tyco
I'm going to use them for PA and siren sounds. (Wail, Yelp, Airhorn ect.)
J. Vigne
I would go to a pro sound shop. They should have what you are looking for as an amp. I would write down every marking I could find on the speakers that might indicate whether they want a transformer between them and the amp or, if it's available, take a digital picture that you can print out of the speaker from several angles.
Home > Message Board > Home Audio > Amps > Archive through October 30, 2004 > Amp for 100w RMS 11ohm siren speaker [ « Previous ] [ Next » ]
