Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through October 30, 2004 > Multiple speaker wires in one wall pl...
Author Thread: Multiple speaker wires in one wall plate?
Username: Zappa
I have one extra pair of speaker wires that exceeds the 8 post wall plate I'm using. If I plan on having two of the speakers on the same 'b' channel, can I put two pairs on the same binding post? Does this screw up the amplifier?
Thanks.
Relevant Product Info
J. Vigne
You can double up the wires. Whether it might damage the amp is a function of the amp, switches, volume control and the speakers. No way to tell you with what you have provided as information. I would ask the store where you bought the amp.
Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through October 30, 2004 > Multiple speaker wires in one wall pl... [ « Previous ] [ Next » ]
