Home > Message Board > Home Audio > CD Players > Archive through December 11, 2004 > Pioneer DEH-P6500 Problem
Author Thread: Pioneer DEH-P6500 Problem
Wheels
I purchased the deck a while ago and it worked fine for a good 4-5 months. The all of the sudden I turned it on and the volume would not change down or up it was stuck at a certain level. I proceeded to remove the entire deck and unplug the main power source to try to "reset the deck" as I was told. Now the deck will not even turn on at all. Any help?
Home > Message Board > Home Audio > CD Players > Archive through December 11, 2004 > Pioneer DEH-P6500 Problem [ « Previous ] [ Next » ]
