Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through October 30, 2004 > Which are the best floorstanding for ...
Author Thread: Which are the best floorstanding for yamaha HTR-5590
Username: Karl
I am looking for floorstanding speakers around $600/pair. Which are the best for using with yamaha HTR-5590?
Please advise.
Relevant Product Info
Username: Rh1
Post Number: 196
Yamaha tends to be bright so I would match with a speaker that will calm this effect unless, of course, you like it bright. Only your ears can tell you what you like. What speaker options do you have in your area to listen too? Athena Asf, Wharfedale Diamond, Tannoy Fusion, and Polk Rti come to mind initially in that price range
Username: Rh1
Post Number: 198
sorry....disregard the Tannoy Fusion as they are slightly on the bright side, I auditioned them the other day so I guess they are on my mind.
Username: Elitefan1
Post Number: 704
Check out the Paradigm Monitor 7. Lists for $699 and store prices should be no more than$625 at most. Perfect match with Yamaha. You need to keep in mind that Paradigm's are not shielded so if you need that you will pay about $30 or so more.
Username: Karl
What can you tell about JBL E80-90-100 ?
Username: Rh1
Post Number: 208
JBL as a whole are a bit bright in my opinion, unsure about the model you mention....JBL would pair up better with Pioneer, Kenwood, Marantz, Nad, H/k
Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through October 30, 2004 > Which are the best floorstanding for ... [ « Previous ] [ Next » ]
