Home > Message Board > Home Audio > Phono > Archive through December 29, 2004 > DOES ANYONE KNOW...
Author Thread: DOES ANYONE KNOW...
Username: Hotaction
of a GOOD quality phono pre amp for under a 100 bucks? or even 50? im just tryin to connect my tunrable to my stereo (which has no phono inputs) and its just going to be used in my room.
thanks
Username: Frank_abela
Berkshire
UK
Post Number: 82
For under a hundred you should get the Pro-ject phono stage. Switchable MM/MC and actually a rather fun phono stage to listen to. Over here in the UK it costs £45 (about $70).
Regards,
Frank.
grannykaty
Does any one know if Stero and Hi-Fi are the same and if not which did the records have first. I'm serious on this question, I'm 69 and I've got to prove a point with my grandson.
Username: Nm2285
Delaware
Post Number: 41
How does the NAD pp1 compare to the Pro-ject recommended above?
Home > Message Board > Home Audio > Phono > Archive through December 29, 2004 > DOES ANYONE KNOW... [ « Previous ] [ Next » ]
